Which trans filter to use, after switching to steel pan?
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Back again asking a question that has been asked before,
but here goes anyway. Which filter to use, as i ordered a steel trans pan for the first fluid change of this & all fluids except motor oil. It was changed before i saw the car, & is brand new
Tune up,brake fluid, coolant, & anything else that i can think of, to put the 04 XJ8 in top shape.New seals for the vvt sensors, are due tomorrow, so the oil leak should be gone, of at least better.
![Icon Deadhorse](https://www.jaguarforums.com/forum/images/smilies/icon_deadhorse.gif)
![Mad](https://www.jaguarforums.com/forum/images/smilies/mad.gif)
![Red face](https://www.jaguarforums.com/forum/images/icons/icon11.gif)
New metal pan, filter from trans shop, new fluid, no more leak's.
Just water from air conditioner, under pan back on,& cleaned. Mass air flow sensor seems to have some issues, just over 3 volts instead of 5, on high & well over 1 on idle, instead of 1 or under.
Will have to purchase one to get things straightened out it appears
![Icon Smile](https://www.jaguarforums.com/forum/images/smilies/icon_smile.gif)
![Icon Frown](https://www.jaguarforums.com/forum/images/smilies/icon_frown.gif)
