Trans problems!
Rent a brake kit to add a flange to your pipes and use 2 claps per end than just one. This will prevent the hoses from popping off. Also verify that the hoses are hydraulic grade. NAPA sells heavy duty hydraulic grade hoses by the foot for cheap. I did exactly this rather than buying a new oem set singe these still have problems.
Possibly but more than likely the original fitting was weeping. This is a known fix, opposed to replacing the line
Update: Got the line put together, Mercon fluid added, and drove it the 500 miles home with out any issues. Thanks again to everyone for the helpful hints. Now that I am home and in my own garage i plan to replace the lines correctly, and probably do a tranny filter/flush while I'm at it just to make sure everything is good.
WhiskyTangoFoxtrot
06-16-2011 08:48 AM
