Transmission fault correction procedure corroboration needed. Have SDD
Transmission fault correction corroboration needed. Have SDD VCI presently
Corroborate with me getting this big cat restored:
1.Communications failure with transmision control module
History. Began with car not coming out of park. Started just didnt come out of park. Removed console.Swapped a good shifter to fix probem, no change, so put back original shifter. Then checked for voltage on one of the wires with a multimeter. No short created just placed probe checking for voltage on one of the wires. Everything was then silent (as far as the starter) when put in the key and turn it over to start the car do not get a sound from the starter. Kept new battery nice and charged with a trickle charger. Put an SDD on it and received the following:
Dash says transmission fault
It is Orlando FL
2004 XJ 128324 miles 1 owner car (before me) traded in for a Te-sla.
Transmission fault correction procedure corroboration needed. Have SDD. Ofcourse then will work to resolve other DCI.
It is Orlando FL
Everything is silent (as far as the starter) when put in the key and turn it over to start the car do not get a sound from the starter.
SDD reads (as shown in the OP screen shots):
BReyes (07-24-2021)
ps., TCM, and J gate fuses were previously checked out good.
Thanks for your help and patience as I have a full time work schedule.
This is the electronic front module behind the left side kick panel. Thought it would be best to post a pic of it and ask if that is where above referenced capacitor is. The EFM doesn't say TCM. Please advise best course. I should remove it. Should I test the pins in the connector. I only want to do what is proper so as to arive at the part that needs testing/R&R and to minimize issues.
Still working on the diagnosis/inspection of the capacitor...
The location accessed /photographed above may not be the module with issue.
Looking at the 2004 MY XJ Electrical Guide, pg 26 states that the 'TCM is contained withing the transmission.'
Please advise where is the transistor? And if you know who is a recommneded resource/contact to advise on/service the JLR modules (With Pcars, given a car with a CDI issue, I have a contact who resores the CDI). BTW my indi contact is Bill at AJ in Longwood.
Suggestion.
Note all the codes currently in SDD.
Google each one and see what it might apply to. Think outside the box.
Reset codes.
See which ones come back. Focus on those.
Low battery should surely not affect this, but best to avoid it going to too low of a voltage while using SDD.
Consider one of these to help maintain battery while using SDD https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Reset codes.
BReyes (07-29-2021)
Right forest - wrong tree! You have a voltage problem to start with. This will throw many of those codes. CAN bus drops out and you get com errors and incorrect data floating around. Check your battery voltage under load. It could also be ground faults however my first guess is too low a voltage to the system. Once you have good voltage SDD will show you that in the top right of the screen. You can also check some module voltages in SDD live data.
When voltage is good, clear the codes and try to start again and see what codes come back. Post those and many will jump in to help.
Suggestion.
Reset codes.
Reset codes.
Appreciate your comments, and helping me with the SDD. The battery is new, charged and connected to a professional battery charger set at trickle charge, before connected the SDD. This problem first manifested itself by running vehicle would not come out of park
"Started just didnt come out of park. Removed console.Swapped a good shifter to fix probem, no change, so put back original shifter. Then checked for voltage on one of the wires with a multimeter. No short created just placed probe checking for voltage on one of the wires. Everything was then silent (as far as the starter) when put in the key and turn it over to start the car do not get a sound from the starter. Kept new battery nice and charged with a trickle charger. Put an SDD on it and received the following:
Dash says transmission fault"
Now nothing happens when turn the key-nothing. I was expecting that with SDD I would be able to reset everything and to arrive at what components to test and replace defective parts. The SDD reads the screens I posted (see original post). Haven't found a thread on how to reset codes. Do you know how I may reset the codes?
ps. I am trying to track down the communicatons problem, transmission fault problem, and resolve them.
Appreciate your comments, and helping me with the SDD. The battery is new, charged and connected to a professional battery charger set at trickle charge, before connected the SDD. This problem first manifested itself by running vehicle would not come out of park. I have disconnected the battery at different times, as well as charged it, before and after this problem first manifested itself, and when reconnected battery, and before I connected SDD, I charged the battery, then set it on trickle, then connected the SDD, keeping battery connected and set on trickle.
What first occured was, the car started fine, "it then didnt come out of park. Removed console.Swapped a good shifter to fix probem, no change, so put back original shifter. Then checked for voltage on one of the wires with a multimeter. No short created just placed probe checking for voltage on one of the wires. Everything was then silent (as far as the starter) when put in the key and turn it over to start the car do not get a sound from the starter. Kept new battery nice and charged with a trickle charger. Put an SDD on it and received the following:
Now nothing happens when turn the key-nothing. I was expecting that with SDD I would be able to reset everything and to arrive at what components to test and replace defective parts. The SDD reads the screens I posted (see original post). And I see the first line says problem with voltage. Please advise if you know how I may reset all these codes. And what I may do once the CAN drops", I haven't found a thread on how to resolve problem when CAN bus drops out and you get com errors and incorrect data floating around.I checked all the grounds and all clean. I checked all the fuses and all good.
Why do you refuse to find the electrical voltage problem? The first item in your dtc list is for the system voltage. The modules will not communicate with one another when the voltage is low. You have almost all modules throwing faults because of this. You cannot correct the transmission until all modules chat to one another.
To check again, erase your codes and run the check again to see if you still have the voltage issue.
A trickle charger is useless for trying to keep the voltage where it belongs. If you look at the voltage monitor in the top right of the SDD screen it shows the voltage is low. Put something on it to make it stay green while you are testing. During tests there are times a draw of 30 amps made. A low voltage to start drops to a level the modules will drop comm!
paydase (08-20-2021)
I have learned that diconnecting the battery and working must be done with the utmost care, to prevent these CAN bus drops,
I reset the codes
This is a principal problem I am working to resolve
Last edited by BReyes; 08-02-2021 at 01:41 PM. Reason: edited to show the charger i presently and its settings
Hello, OldKarz, The voltage is good and I have rest the codes in SDD. Once I am up to speed, I am able to excel (aside: JLR is not an easy make to master, but ever since my sophomore year in high school when on my walk home after school, when I walked past a XKE roadster everday, I was hooked on the make. An enthusiast still. Enrolled in shop and graduated high school with honors in auto body, later have mastered several makes, and have MBA ).
I reset the codes
I reset the codes
I am working on determining the source of the problem of, shifter will not move out of park position (of course the little black wing procedure gets it out of park, but that is besides the point presently as problem now includes, it will no longer start), no light on the shifter, no start (no sound when turn the key):
History. Problem began with car not coming out of park. It started just didnt come out of park.
By posting, I also hope to provide help to others who would follow.
- No light illuminated on the j gate.
- No beeping (I dont recall if it was earlier, but presently no beeping [With the key out of the ignition, moving the shifter to the left closes the not-in-park switch and a beeping is heard from the instrument cluster]).
- Fuse F33 (passenger footwell) is good.
- Brake switches: Seem to be working, look properly aligned and brake lights are operable. May have to revisit again with more definitive tests.
- Mechanical problems investigated, none found yet. Checked shifter cable bolts at the tramsmission and both were tight. May have to revisit again to determine where else, other than at the transmission shifter cable bracket bolts, I may check for slack.
- I swapped a presumably good shifter (I removed console) in order to fix probem, with no change, So I reinstalled the original shifter. May have to revisit again with another shifter assembly. Then checked for voltage on one of the wires with a multimeter. No short created just placed probe checking for voltage on one of the wires. Everything later became silent (as far as the starter) when put in the key and turn it over to start the car do not get a sound from the starter. But between determining would swap shifter and where am presntly it doesnt start (makes no sound whatsoever) and there are no lights indicating what gear it is in.
- I haven't found voltage at the connector (green) to the shifter assembly. I have to check my notes about what wire I previouisly tested for voltage (and found none).
I am interested in determining why the j gate gear indicator lights are not illuminating. I am looking at the the green connector and the wiring which seems to disappear down and rearward below the carpet/seats:
Here is a pic of the connector/wiring I am interested in testing next
And the following are a couple of schematics:
