Transmission fault correction procedure corroboration needed. Have SDD
#121
Keeping busy and 2004 XJ8 diagnosis progress when have time. Thanks for your help!
Been using the SDD and over 7000 page Shop manual.
I ran this test jgate pin out test early in the process and am back at this as this is the one test I have mentioned in this post as the only one I have questions on as all the other tests have passed.
01/22/23 ran SDD and a jgate connector pin 1voltage check
SDD says some modules offline and first two picks are showing which ones.
pin 1 volate was at 20mV and Shop manual test of Jgate tells me to repair the circuit between jgate connector CA245 pin 1 and the rear power distribution box. note this circuit incorporates the ignition switch and the primary junction box. For additonal information refer to the vehicle wiring diagrams.
Questions I am working on and appreciate comments on the next step.
-it is CA245 the green connector, correct
-is the rear power fuse the large fuse box in trcuk at rear most near bumper. which is no 3?
-which is primary junction box
what steps (parts R&R )would you do next?
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/zz012223aimg_1989_e5913cb29627ef50ca17b7038248af6d8155fcdd.jpeg)
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/zz012223bimg_1988_d23f9d8952a668ad4647b1e3785341c510ef87f9.jpeg)
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1198/zpdfjpgscreen_shot_of_a_jgate_test_71f2b3c23e79fc09754a99820fa379814e8f71b3.jpg)
#122
As OldKarz says, your voltage dropped off during the test.
Yep, soooo that is exactly what happens using a battery maintainer or battery charger that is not designed to maintain a constant voltage at 13.8 vdc at diagnostic currents that can exceed 20 amps DC.
Chargers and maintainers adjust the voltage during the cycles and at battery full charge will drop the VDC to about 12.6 VDC or even zero / off if the battery is full charged. Don't believe me? Put a DVM on your charger or maintainer and over a typical charge/maintain cycle you will see the charge cycles working and varying the voltages.
Don't be fooled by commercial chargers with high cranking amps, they are only big because they produce more amperes through a larger transformer, unless they have a very specific feature to set AND HOLD a constant output voltage of 13.8 VDC.
To properly diagnose all the modules on all the Networks, the voltage on the system busses must remain stabile at no less than 13.25 VDC MINIMUM.
The LAST thing you want is your power buss voltage to drop to battery voltage during programming/copmmissioning of a module, that is called "making a brick".![Icon Bricks](https://www.jaguarforums.com/forum/images/smilies/icon_bricks.gif)
A 45 amp DC power supply is like $25 USD throuh Amazon, plus sacrificing a set of cheap $10 USD jumper cables from Harbor freight for wire and clamps, so why risk making a brick of a module that is worth $100 used or $1000 new?
That is called false economy.![Icon Wheel](https://www.jaguarforums.com/forum/images/smilies/icon_wheel.gif)
Just do it correctly and eliminate one source of your testing failures that have you diving down rabbit holes.
#123
![Post](https://www.jaguarforums.com/forum/images/icons/icon1.gif)
This is the one I bought +3 years ago and use regularly. It is $34 when I last checked shipped free via Prime membership
![Amazon.com: Henxlco AC 110V/220V to DC 12V 40A 480W Universal Regulated Switching Power Supply Adapter Transformer Driver Converter for LED Strip Light, CCTV Security Camera System, Computer Project : Electronics](https://www.jaguarforums.com/forum/images/misc/amazon_icon.gif)
PARTS and work TO ADD:
- A pair of battery post spring clamps from your local car parts store like used on a standard battery charger for about $5 and enough wiring to make up a 40 amp attachment cable that can handle the 40 amps between the power supply and the battery,
- or sacrifice a cheap set of jumper cables for $10-$15 using the end set with the battery post clamps and the other end cut the clamps off, strip for attachment to the power supply screw terminals; For that you will need some crimp lugs to separate and the attach the stranded wire to the three + screw terminals and the three - terminals. I used three #16 AWG wires because I have spools of the stuff for my work, three wires for the +12 connection and three of the same gauge wires for the -12 connection wrapped together the full length with electrical tape to make a flexible cable so I could attach to the three positive screws and the three negative screws with some crimp connectors, and crimped the three + wires together to the RED battery spring clamp and the three - wires together to the Black spring clamp. Doubtful you will ever pull 40 amps running diagnostics, but I have seen up to 15 amps draw during diagnostics. My cable will handle 3x17 amps for 51 amps draw as a margin of safety.
- and a power cord which I used a three wire cable used from a old power strip and cut one end off, or buy a cheap 6 foot extension cord and cut one end off, strip and wire with crimp lugs to the 120VAC L-N-G points
- Any Digital Multimeter to check the power supply VDC and a small flat blade screwdriver to adjust the voltage to >13.8 VDC
For all the diagnostics OTHER THAN continuous STARTING, this setup works as per the Factory Manuals.
I am quite sure there will be a lot of other opinions and methods.
Cheers!
![](https://cimg5.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/img_20230201_130503649_076a44bb5aa3d1abe55f5efc5c0ab50ac6412804.jpg)
Alternative Diagnostic 40 Amp Power supply terminal strip wiring example
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/img_20230201_130530335_c13e5515b9459fa0f5da2e54ab8212ba440256da.jpg)
Example of my 40 amp Diagnostic Power supply battery clamps
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/img_20230201_130547111_hdr_4dffcb8ba8dee80450f3a847ac7a55d104d6bb09.jpg)
Example of my 40 amp Diagnostic power supply power cord
#125
#127
#128
Here is another one
[img]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQAAAQABAAD/2wCEAAkGBwgHBgkIBwgKCgkLDRYPDQwMDRsUFRAWIB0iIiAdHx 8kKDQsJCYxJx8fLT0tMTU3Ojo6Iys/RD84QzQ5OjcBCgoKDQwNGg8PGjclHyU3Nzc3Nzc3Nzc3Nzc3Nz c3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3N//AABEIAEYAfAMBIgACEQEDEQH/xAAcAAACAwEBAQEAAAAAAAAAAAAEBQADBgcBAgj/xAA7EAACAQIEAwYEBAQFBQAAAAABAgMEEQAFEiETMUEGFCJRYX EjMoGRFUKhsUNSwfAzorLR4QckYmNy/8QAGgEAAwEBAQEAAAAAAAAAAAAAAAECBAMGBf/EAC4RAAEEAAMGBQMFAAAAAAAAAAEAAgMREiFBBAUiMVFxE2GR4 fChsdEUQlKBwf/aAAwDAQACEQMRAD8A4qxDsX4ZEYPJfyjpviI23Lw4Y0VKJoKpV lJiCqzb/KdQ53A8zh1SZNRwqWgraFnYbNLGCR/n2w0LNpTSyKGijZlP5zsv3O364MgyTNZtWiAKADuzAava/PGjoI85MMkjQwQopIE0KIyH6l9vtioV0086K1ZRPKhPCYFQwYi 35W/v9MI5C1TG4nBvVTsv2NjrK6ljzObSJpQrxxm7AX6GxF/2xo6XsT2XqUjqv++jpnBZtcttAEkKne3Ia238vbC2DNq+Jo6uj NGeHZ+IurwsLHyII352t0tuL3w9oM7l4pjoDVrEwdxTKh4QBU6 f8MWW8akjltvjFtLJnOuN1DvX+dlWHBkUzh7K9m6cTTvl06PDx dUclUrAhIVk6AjfUPEOm/XDbMshyTKMtrczio4F4Cv4n3N1l0C59gfrjNP2hzHXIX7NVdyC 8kckN10tGIzddNgmhQvK23nj7btJm1TFKs+R15SVDqVKZiGRn1 lvlAsWJ3xnEW04mkSADK8z6JHDXJbFIKFRTAwk8YwppV7n4hjA flsPG2x8seJQQSR01Rd+HULdBstrhWW5I221/b0xlqTM6ymnkqo8slgmlEVzUURFytljIDbX8IAI5kYv/G8wQRQEeCAIVTu4YKoDKptubWL+9j5YToNr/bL9fmqXB0ReYyU1Jl+XVdTM9IlRUIsjGYMoQl9dtI/KFXxcjfBMWWUFXJGXaQa3Okd4EgItCQVYbEHiXB9RhFU10TRJG sVUi0riaIRZc2mPRc3sF2UFyPLliiHP62o0TUb1MyTSDhGHKri 6hbhDpO1oluB/Li3R7Thyk66+iODotcMgy86FZZEvMiH4ykqSYho5bkh2+2ENZl GT1bZLDLCkpzCYK4uLqBZWsel2D+wwjgWeN6doaesLRVLZjD8P SS/h1PuN18K36D64BrKntFFW09VRUUyR0rkQIlN4FZjqtZRYklrgW 6jA2HaG3ct/35Efek7b0Tmg7HZBVNHemmLaDO4grQ6SBu82jVrAWHAXxX3vhn +F9k1lqIKmnEksE8sRd5Wu1nNr2IF/P1xz4drM9oqZMvd0VUQj40A4jo6vYM1tRFpnIP8A5XwXBnKVxl qsyihaplkLuWQDc7kjbkTc/U477PFM2Que626JOIrIIWjlgq4MyTRHCXgubNsQCCDy6YZZTLk FJTlqg0pl234Wo8rG45874z0M8ixSqkUXCKyIZB89ihOm/lt++F5ADkAfTnjYopdgy7PIJAix1NNKijZEYKQPbp9sWTTUFSc 373TLIwg4lE/DVjG2k739GFwdzjjqQ8e4W/hG58saHs1mfd6k0M9Q6R1KGFJHJbhOdlbnYKCd/TEODiKBWjZ3xscS8afXmPtXZdDiybJ/hGlp6kVfD8UcUzLHawB1AnTvcdLe2F1PnkPZ+gzOr7ug4Yjjii 41pHluwIN76h+a4G464z/aD8Uqe0FRl00s1Nl4ijeoubKkehGbURz3NreewwG9S0LSU+ZrF wamoCrCRpZIDfxlfyW8LC+97+ZOOUsIdHgdn1887XVjmyOfoOY 8l0ebtPl8lR8HOaNIo3Ejk1qAsA0uq24uLGMgC5N+tseJmNKUn qoc1WqM6aoY+9oY42Ctp5C4BNtQJuOe3LGRpOzFLlsrLIe8Six DyciOYIHIdD/XFFfNJTyMqTOGHOOYa1+/P9TjGN0x6OKzmQg0QugLmuVCVuLPHIhmVlUzK51rLrUi3JdSr7 C+KZc1yqNeE1XTx1PCjDyGQAMq8QqAepvI9/Lbzxzla3vF7Lwp03Kg3v6g4YoY80pdJBEoudtyGtyHvbYcjuOY BKG54v5FHilbOvzbK62IoudU9G2kBpoqqND4bgEFrg3Gnbrvbz GZ7M1tPH2fo4qzMKMPHBNDHT/iAi1qY6i3EDf4bhnsHBsRKOo2ydTE0MhSX5GFyV3BX+ZeV8fE9 KnCDJpjFrq7Otz9Bvb3++OrN2MZGWB2R9/ykZCTa3VDmUbRUSVWdUEOum0VBhzQfBCCAJJHceGTw2aM7NwyQ N92sWbUUdXRyHM6NEtEgVqlQS/FgYHTfcWVvFy2IvjlFKk0tQkca/FZgADt9/Iev1x5ULHGwraOWpnippLFZibkH5ZB5KSLW6WFyb4h+7Yyc3IE hRXbmup6/tPUVNDw2gljpyirZlX4MYK39CLfTCyGeONSpo2c33KSlR9t8FU qwTTxWhhRUYERkkhrm27XHqenL1xalJTy3cVEMF2N1eJ2N+u4P nj6McYjYGDQUoJsofiyoF4UMLpIL2K7nYg9ffHrVFVGumHh04/9aAYIoYCrtLpYx3KarbBrA2998UZlcRErfn0w01bA5nhK1Uil2 BOsgDcDw8ve+PDlsYihVJSskseu5h1E+o35cuQvhllVJBIjrLK tPpl0d41aSigcgSRa9vPDLK4Y8uzSr7rJK0NMbRwupu7kXDA2t 8w9b8/aroJVZTqur6YVdTTuePNBG1RKryB9Ew1SBLcyENgARbcj8otiJ q/MszlqYKh01eLjJEgUah4SzEbk36k9fbFhzvM5KqeTjRQVCm5jU gKDfcajv0OxPXngiPLquojjqpUKRzytAPAsvjAuVIJDjYg9eYx DnBpzXdjDI0NbzCZwZlJHlmWQTNHJMsTxXjNwdDn+hA+mBayVa saWsJF+Un9j6Y+JKaOOSiXK8xpBNRo6aePoLOxOsLq+gBucGNV ZwiNHMYxpHOujJDm19iBa3ucNhBFJTxOa66yy9azQctHDXUIlo E4NdT7ul+f3P98sAUVcVfjItmHhliJtt/e4PSw6jA0s8ktQ8dRHGJRaxiYMp9P7/wBsDtqR9afMOY8x5YtcFr3pkzKkRkI4dzaRiBobnc9SSdmHsR6 ootVJO0MjCKx3dI1dl/8Ak+XqDiugquFIjldUYYMVYXv5g9fsR/TDTMoqapqaiuZ4oKdRxGjhjVAsY6KBtc3sCbXNvMnASALSztWU GSvmWaU+XQJNDU1gbjzT/NFTD55DtsTYqL+o6jGs7WZA1V2Xpc7pqKNFo4mQUcalTLl5+UP ffWF8d9rEna4wd/07yej/AAOrr82kgFTnKWeIS6TFT2skYINx4fY2t1GNTlS5fTNWS/AheeUqweVWLInhW5ubg2Lb7+Lfyx5DeG9HfqCWXwH16j3rTzW2 OIYc9V+aK2CSgqSiSlkKhopRdeIh3B/46HbpgujQywDWblSRu31/rjVdrez0VHnUmVUjrLASarLFiHFLKd3gsDzBuQPK/MtjOzRdzq6qmWC3DndSCQtt+Vjy2ttj1EErZow9uqyuFGk3iki hpa6mlBBkZJIiB+YXB/Q/phe+ggLIgcu6ot7+G53It15c7jc4Y1EZL6hyI2OA9ANVGGXbUT f6E3x1ISCIo4OJkWZyylQjKrnxlf4igk2BuB7dRa/LDdMsqaehWkVp4KuRrrwnI0gMI7azYi9gL9fbkT2Clpe8xLV1Q ZUkVG1xnSoDDSvqPfcWx0btnlOVpSTVsVSVBQqEikvrFwwvvv4 h19eWMU+0+G8NAWmKEOFlcRp6erzCoEUNMksb1gu4tZWN/wAwJsOtrnkMVZlW1OVSNlcas1OAbksQ0inqLHwrty8ud8aDLqv LjmA44aJ3DRxkgDgXDI1gPU7m17JufNbVZBDBLJDmCZmxgfSPg qpPlaxYspA+YAD2xqHEc0rMcdt5nX51S/L6WCvkEURNks8jubNAo/MTyI9vTYdZDnU+X10xdOPl08rPwJN1Kk38P8rD0wY1I9ZTpFlz wvQXu0ERKNtyJNyWPubeWDMuySWp1NVxS01FHtJNIu9h+Vbj4h 6BSCRfmMU4Cs1ziLsXB87obMq/KKWqkgNFxAhDIzSgXBAINgnOxGBfxmnnOmnoI289TStb7MME5w 1BX1iNRxSyyyMB3VoSWQAfKhFwdO+xtf8AZaRChc5lNcK1hBEL FiPPlb29B5YoXWamTDjODleXZERVVTJMwpqCDUQNhFqt6+InB4 cqhhzeppnici9KqADUOR8NrHc4UHOkVeFBGVi5LFHZR9TzOJFJ VhPg5aiJvd5Fb9WJGCrFKEzP4OQdOTw2HVmcsfYBrfcjAgFNIx YZZl8UfTUJL/68eQ08lSkj98p4tCFnWJtWlep8N/LzwCHoApWR6ic3urBQg+5J/bE+G1FppA9PTzrUw0tDEIJEPFWORjGb7NfVbYgbHngYVOU0/wAOoR2cfxEv8QdG35E4qhkHDPc6FCSCrB5CxsADvuo+luh8sfE WYTabxiJVJvZaeMD/AE4oNDeSCbTdqkRiOFlJbgqwb78/tj1N6qJ33I6X9LYmJhoVWS1dXpkjVozDrGmMqBZ7GzXtfkLeew 32xZHUZrVAxyS05DPrZypLk7mxPUbkW5AYmJiSxpN0qD3AVabR yVWneReMqlfhAQr0G4Ub7Kv2xZQ1Wbw2SSuieBN44Gpw6IfTVc jryOJiYYAIRjc02CrRXJFUAQ5VlK1LAs8/c0ve/QEG3vvhfmOVZ7nEklTV5ojwoSq3LXA9EtpH0tiYmKDQgyvIq1m 0ko8rrLpUVrzxt/DRYhf3Jb9sE1M9LU5dUZn3Re8JMsZEpL31XN9iB/lx5iYSlL6atmMyoJTBGx37uiof0t++PjM4GinjZ3MgljEiliSR fzviYmEhDRuyElGIuLGx5jyOPFFtXvtiYmBCvViQOhHXFyR+HE xMNJf/2Q==[/img]
8:41
8:41
#129
Here is another one
8:41
8:41
#133
Thanks to Dave in Orlando. Dave stated, 'Found electrical short in shifter interlock, repaired damaged wire, rebuilt inner shifter, replaced fuse.
A/C recharged.'
Thanks to each of you who helped. As you may know, I appreciate you. Hope to see each of you at an a National or regional event.
Best Regards
A/C recharged.'
Best Regards
Aarcuda
08-15-2020 05:23 AM
Naso--Lituratus
04-02-2015 10:44 PM
Lagonia
01-30-2015 10:16 AM
Bladevane
02-11-2014 02:23 PM
