Transmission Fluid change
Hi,
My 2008 VDP is approaching 100000 miles. The transmission drives like new. I wanted to change the fluid but after reading comments about transmission failing soon after the oil change I am a bit apprehensive. Can someone please advise what should be done?
Secondly, in case it needs to be changed, can someone please recommend a good mechanic for the job in the Central NJ area. Thanks.
Silver Panthera
09-09-2021 10:48 PM
