Transmission leak 2004 XJ
Serviced my transmission due to a leak that I diagnosed as a leaking pan/gasket. No oil leaking from rear output seal. The service proved challenging and semi rewarding. Once completed, all residual fluid cleaned from area and a 10 mile test drive, I parked the vehicle and placed a piece of cardboard under the vehicle overnight. Unfortunately for me, it is still leaking somewhere near where I thought the original leak was located at the rear of the trans pan.
Any ideas, opinions would be appreciated. I was unable to have the convenience of having the vehicle on a rack for this repair.
Thanks in advance.
D.W.
Thanks in advance.
D.W.
Did you replace the sleeve at the rear of the transmission? They are prone to leak.
Check https://www.jaguarforums.com/forum/x...eekend-104279/
There is a plug and socket connection at the rear of the box for the Transmission Control Unit that is inside the transmission. This is sealed with a rubber sleeve and this has proved unsatisfactory on earlier models so needs replacing if it starts leaking. Later seals are claimed to be better, and you should get the improved when you buy the replacement. However, it's not OK to just replace this sleeve, you need to check the pins in the socket are not contaminated with oil, nor the plug pin housings. If they are dirty they need cleaning out before reassembly. An aerosol of cleaner will normally clean and blast out the dirt.
lcmjaguar (01-17-2016)
Okay, spent a coupe of hours yesterday servicing the transmission again. This time it included changing out the electrical connector sleeve. SUCCESS!! No more leak.
Thanks for the help!
One question, what is the small two wire square/rectangular sensor bolted to the right rear of the transmission case near the trans filler plug?
FS[NorthEast]: Transmission Fluid- Jaguar (C2C8432)
magmedia
03-13-2016 10:38 AM
