Transmission leak after car sitting for a week.
I had the transmission fluid and pan/filter replaced around 6 months ago. Twice I have noticed that after the car has been sitting for prolonged periods of time, transmission fluid leaks.
Both times the fluid puddles were fairly large.
I don't think the shop replaced the mechatronic seal.
What do you think is the cause? If I use the car regularly, I see no leaks.
I've owned several classic cars and the ones with automagic transmissions all tended to leak in the same manner. The joke in the hobby is that if its not leaking, its empty. It was explained to me once that since classics sit for weeks or months at a time, the fluid in the top half of the torque converter drains back through old internal seals or worn check valves in the valve body, thus eventually overfilling the pan. Seals like on the side of transmission where sensors and linkages penetrate the case work fine against the liquid being splashed around inside, but were not designed to hold back the force of being under several inches deep of fluid. Even the pan gaskets are under greater pressure to leak.
Steel pans are overrated IMO. Most modern cars have plastic pans today and you will find failures but unless you're off roading, your chance of a leak in plastic over metal are nil.
If you're old enough to remember GM's TH350, 400 etc, the pans were all steel and often leaked like sieves. I think plastic is an improvement. Often the leak is the result of tightening the pan bolts in the wrong sequence or over torquing the bolts.
It's your car. I've replaced on my X350 with plastic and my XK. My XK pan (same tranny as the X350), was an aftermarket bought from a German distributor and likely made in China. Doesn't leak a drop and I paid $64 for it, including the gasket and an entire new set of larger headed bolts.
Just a different perspective. I'm sure you'll be happy with either in the end.
Main reason i went with the steel pan was, plastic one was leaking, they tend to warp from what i read, also the filter is part of the pan, bad idea (my opinion). The steel one is reusable, as is its gasket, steel, & rubber, the filters are in the $20 to $30 range, so even if you replace the gasket every time the filter is changed, you still save some cash.
acetrebo
04-25-2017 08:00 PM
