Transmission oil change report. Castrol ATF
#41
thechizza, thanks for posting man.I love going out of city limits with the car just to enjoy driving it on the open roads.the thermometer is needed to get an accurate reading on the fluid temp,which will tell you if you have enough/too much in there.Any thermometer works fines because you have a 10degree celcius window to cap off the fill hole.
#42
#43
#45
well I changed my motor oil today and good thing I DIY... On the bottom undertray I noticed oil spotting right where the transmissions electrical connector (you know, the one that leaks :/ ) is located.
so it looks like my electrical sleeve isnt safe from that leak, good thing Im going to change the pan in a month or so : )
#46
Hey Strateloss
I bought athe atf fluid and was gonna try to attemp to do the transmission fluid change but am a little nervouse about it, I was wondering since I live in NY would you attempt to change it for me? of course I would pay you, also I wmight be able to watch what you do so I can learn (I'm not a mechanic, but am pretty savvy with repairs.... thanks
#47
#48
Wheel spin is not necessary. You just have to get an engagement in reverse and drive like you already performed.
When the transmission is drained there are always a couple/few quarts left in the torque converter. This is why you won't be able to add the same amount as listed on an initial transmission fill.
#49
Thank you Frank!
I had the dreaded sleeve leak and when I drained about 7 qts. came out.
#50
Hey Strateloss
I dont really have the time to do yhis nor the will with the humidity. Let me know if you want the shop. I can get you an exact address and phone number.
#51
The wheel spinning IDT is neccesary, I only did that when I was doing multiple drain and fills in one shot.
If I didnt I would be draining all new oil on every drain but the first.
I am nearing 80k so come september when this heat sdies down, change filter gasket and electrical connector then no more oil changes for the life of the vehicle.
May just get the TCM firmware updated afterwards.
#52
Disconnected the battery terminals, then I let the two terminals (NOT THE BATTERY POSTS) touch for about 10minutes (lit up a ciggerette, walked away and smoked it , then came back) and reconnected tbe battery.
Or just disconnect the terminals, leave it disconnected for a while to drain all the circuits on the ECU's and resistors (a few hours). Then go back and reconnect the battery, start the car and let it idle for 10minutes.
Now, how much voltage does a resistor store, that it can be drained.??
#53
Sorry to keep intruding on you guys, I am just perplexed about this "mysterious ZF". When I changed sleeve, pan/filter and switched to Castrol Import, I did not disconnect the battery or "reset" the TCD at all. After buttoning up the tranny, I simply lowered the vehicle and drove off. I did not notice any difference in how the tranny shifted, sounded or the like.
My question does the ZF still think that it is being lubed by the original ZF fluid?
#54
#56
#59
#60
I did this following the instructions on you tube....just google jaguar transmission fluid Chang you tube Great video ...it's a xk8, but a model with our transmission. I used the same fluid and filter. It has been 5k miles and shifts a lot crisper.
I used a cordless impact gun and had no problem with the bolts. If you have a stuck one, just drill off the head. This guys process is to intensive.
