Transmission problem 05 XJR
Hi, my 05 XJR has just developed an intermittent problem in the transmission since yesterday. Every so often, it refuses to change to a lower gear when the car is driven off from a stopped position and remains in 2. I noticed this happens more frequently when the car is in the sports mode. It has no obvious relation (yet) to whether it's the first start of the day or later (but of course this has only occurred since yesterday.) Interestingly enough, the car does change to a lowerr gear when I flick the selector to the left, "manual" side, of the J-gate and then flick it back to D immediately. No error codes have been displayed over this entire period.
This staying in gear problem has happened about 3 times yesterday.
Today the car seems fine although there is a hint of the engine staying longer on the same gear in the sport mode, although it does change over ultimately..
I'd like to ask if anyone has any real idea what the problem is. Thanks
Thanks for the suggestion. Just for my better understanding, how does the mass air sensor link up to the transmission? I know the electronic links on this car are complex. When I had the dreaded throttle body problem, it also showed up as a transmission error message so I was stumped into figuring out the link, but of course this time there are no fault codes shown (yet).
I do believe most cars get data from the MAS or MAP sensor on how to shift. The same was true to my girlfriend's 2000 Cav. The vacuum line came off the MAP and it was shifting hard. Also, the ZF starts in 1 no matter that mode it is in. I do know the older GM trans in the 95-97 XJR would start in 2nd unless you are in sport mode.
I wish the car started in 2nd. All that torque with a low gear can make driving a little difficult off the line. The 95-97 XJR has an 4L80-E GM trans. All other XJ6's had a ZF 4HP 22 or 24E. Did Mercedes make it for GM? The way thinks work in the past 20 years..who knows who made the original of anything.
KarimPA
09-03-2015 07:32 PM
