transmission shifting
Received 2,678 Likes
Here is the response I got from ZF.....the same solenoid is apparently responsible for hard shift from 1st to 2nd and a slow shift from 5th to 6th gear. In my case, changing the fluid did the trick though I still have a slight lurch first to second. Next time I change the fluid I will switch the solenoidThe P0829 code is for a 5-6 shifting issue. The pressure regulator EDS3 comes on in 6th gear, but it also comes on in 2nd gear. I would suggest replacing all the pressure regulators with a ZF solenoid kit. You can purchase it at Eriksson Industries (800) 388-4418..
Steve
Steve
ronrowand (09-19-2018)
sandydlc
08-11-2011 04:34 PM
Christian 96 XJR
06-03-2011 12:54 PM
