Trembling steering wheel issue
If it is the bolt you need to get that sorted out immediately as once it loosens the upper and lower steering columns can actually disengage and you could be left without any steering input whilst moving.
It is so easy to check if that is the problem - just remove the upper footwell carpet (IIRC two plastic screws) and with a torch you can clearly see the bolt where the two shafts connect. Keep the key in at position 2 to unlock the column and wiggle the steering wheel. If the upper column moves and the lower one does not then you've found your problem. A dab of loctite and a few turns of the bolt and you will be back to new again. If there is no play between the two shafts then the problem is something else.
Received 9,011 Likes
Thanks Dave, much appreciated.
I'm heading down to Brighton for a wedding this weekend and aim to get that checked and everything else more in depth if required to get to the root cause
Was this problem resolved? I too have replaced all suspension control arms and stabilizers with Lemfoerder originals, nerw OEM 18" wheels, new Bridgestone Quiet Trac tires, new bearing hubs, etc. and still have very slight shimmy/trembling at 60-70 mph. Have not done road force balancing yet.
I have not checked steering rack mounting bushings or steering rack play, but was thinking that might be something to look at.
Car has 79,000 miles and not very abused. Any suggestions by those that have resolved this would be helpful
Mark
Hello all,
Mark
Mark
Perform a power steering fluid swap out and replace with Ford Mercon SP.
I had a low speed shudder at the steering wheel. Lived with it until my pressure line spring a leak.
Original PS fluid spec was Dexron III
Since I flushed and replaced with Mercon SP - butter smooth at all speeds!
