Tricks to Control Options
I have just found out how to disable seatbelt chime. Tell the group what tricks you know how to do to change varies functions of your car that you don't normally know. I found out one for the seatbelt chime.
For chime only:
Sit in vehicle, passenger seat empty. Start car, with seatbelt light on, latch seat belt, when light goes out, unlatch. When light comes back on, latch belt, repeat this 8 times, you will get confirmation chime. To reenable, repeat procedure.
Please share what you have found out.
For chime only:
The following 5 users liked this post by Chuck08XJR:
blindboy (03-24-2013),
EBoyTropic (04-28-2011),
H20boy (03-24-2013),
jadedragon1800 (04-20-2011),
shinebox2 (06-16-2016)
DB6, try to see if this helps....what ever screen/setting you had have on while you're driving, hit the menu button and turn your screen off ( i don't like to have my screen on while driving...call it part anti-distraction, part i don't want it to "wear out"). when i restart the car later, everything is as i had it when i stopped the car, and it's on the last screen before i turned the screen off......hope it doesn't sound ridiculous. i also hope i understood your concern about the NAV settings right.
![Icon Emm](https://www.jaguarforums.com/forum/images/smilies/icon_emm.gif)
There is a hidden menu in the NAV system. I found it searching this forum.
I don't remember now the keys that made it work, but you held down two of the Nav units keys and got a hidden menu for the effort. I wasn't overwhelmed with it at the time, but it did work.
Maybe someone can chime in here with which two keys it is.
The following 3 users liked this post by u102768:
Interesting. That wasn't the hidden screen I had seen. The process was the same, so I am thinking there must be various three number codes that give you access to other screens.
I was able to go in and find some interesting features and status info that was standard in the user menus of other cars I have had such as KPH/MPH, battery voltage, elevation, etc.
I Still have not found the original message, but I did find code 1971. At first it appears to be identical to 917, but there is an additional option that allows you do define what equipment is added to the NAV system. This is where you could tell it you added a phone or rear entertainment system.
There are more codes out there because neither of those show the menu I remember seeing.
