Trip Computer Question
To the bottom left of the dashboard where the fuel release cap and the boot release button are is the A-B Reset button.
Press the left stalk trip button until you either get the A:???? or B:??? on the Instrument cluster this will allow you to press and hold the reset button until it zero's. A quick press of the A-B reset button switches between A trip and B trip.
The fore and aft on the turn signal stall switch between main beam and full beam headlights.
Hope that helps.
Hope that helps.
philwarner (08-30-2015)
Hope that helps.
Hope that helps.
Tomorrow I'll check out the A-B shift, and see what is already recorded there before I zero them. BTW, the Nav told me where this car's home was in Houston; too bad I had no time to go there and perhaps learn some of its history before driving it back to Arkansas. The Nav also told me it had been to Hooters which says something about the previous owner, too.
Thanks again.
aholbro1
08-05-2021 05:02 AM
