Trunk access through the trunk that nobody talks about
I got the trunk opened through the rear seats. No one talk about it . I had the valet mode on so that was the only option
Pull the hidden strings at the base of the back seat tucked at the bottom where the rear back seat meets the seating part and pull them also the rear seat at the same time .
You will find an aluminum cover plate that you have to remove
Then an opening to get to the trunk
You will have to cut the material to get through but you can later repair it
Jaguar Forums Editor
Jaguar Press release
04-03-2014 02:08 AM
