trunk actuator problems RESOLVED
Have fun ! Actually it is not all that bad a job, although the modules are a bit expensive. Newer ones have longer fins so should last a bit longer.
Does the actuator in the trunk lid make any sound at all when you use the plipper or the button ? If there is a noise but no action it suggests damage in the actuator assembly, possibly caused by you forcing down the lid.
If there is total silence, it is not uncommon for one of the wires to break in the wiring within the visible corrugated trunking at top right of the trunk aperture. However, I doubt if this is caused by your loading up the trunk.
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
