Trunk/bonnet won't open
I have a 2000 xjr. When I push the trunk button while the car is running and in park, it beeps and displays "valet mode" on the dash. I've tried using the valet key and pushing the valet button to no avail. The black will not open it from the trunk key hole and the button does work either. Help!
Thanks and yes, I always use the primary key as my fob doesn't work and I am way to poor to own this car. I've had it six years and it's 15 so you know how it is. When she runs well, you can't pry my hands off. When she's broke, f da hoe!
I got it! I took the licence plate off, drilled a hole in between the top licence plate holes, then used a bent piece of wire to "Jimmy" the linkage to open the boot. Then reset the battery by removing the neg cable and putting it back on. In hind sight and looking at the diagram of the latch mechanism, I would have drilled the hole lower and just used a screwdriver. But this way you have to use "the trick" to open the boot. I sealed the hole with a piece of metal duct tape.
Beachskidder - glad you got it sorted, but at 2000MY yours is an X308, whereas this sub forum is for the X350, 2003-9. The forum you want is
XJ XJ8 / XJR ( X308 ) - Jaguar Forums - Jaguar Enthusiasts Forum
You'll get more help there than here![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Cheers just now
Dave in Gloucestershire
Cheers just now
The car has been started multiple times with the black key. The book says to lock the doors with the black key, then unlock them. I don't recall seeing a button in the glove box, but I'll go take a look, Everything seems to work OK except the trunk opening button. I seem to remember that in Valet mode the performance is supposed to be reduced as well but maybe only if you start the car with the green key.
I can open the trunk with my black key, just not the button.
