trunk and glovebox access with a dead battery
(2004 xjr) Battery went dead (original battery so perhaps no surprise there...). With the battery dead I can't open the glove box (to get the owner's manual) and neither can I open the trunk to access the battery. I've heard one can do the jump via the underhood fuse box where two mysterious "pins" reside but what do I do with them. They seem not to be labeled plus or negative???
You can open the trunk with the key. Look near the license plate lights and you will see a location to inset the key. If its not been used much it will likely appear difficult to turn. You need to rotate approx. 90 degrees to open the trunk. Good luck
Key does not do it. I called SIX Jag dealer's service departments (to ask which of the two pins is positive/negative so I could connect my battery charger - that's all I needed to know. I had NO success with the dealers. . In three cases I was unable to speak even to a receptionist, or I got put on hold with a dead line soon to follow! (what if I wanted to buy a $100K XJL?). With the three other dealers none of the techs knew the answer to my two pin question! I was getting desperate! Does Jaguar not have a system whereby if not one tech at a dealership can solve a problem they can go to a company expert outside that dealership? Maybe they do and my off the road XJR wasn't worth following up on. No money to be made there, hey! Hold you're breath no longer. The answer to the " two pin" enigma is (drum roll here...) is that BOTH PINS ARE POSITIVE! I got this simple four-word answer from a website justask.com It cost me $36 and my anser arriced in four minutes! Beat THAT Jaguar. The longer answer (which I didn't need, but which someone out there might someday) is... open up the underhood fuse box, spot the two metal pins (they're in plain sight!). Connect your battery charger's positive to either of the two pins and the neg. to one of the four strut tower bolts just inches away. Seconds later press the in-car trunk release and that's it! It's worth noting that this procedure does NOT charge the battery. By the way, the services offered by justask.com are not limited to car problems...
That may explain why the key wouldn't open the trunk.
Also, please post an intro in new members section.
Don B (07-25-2016)
Johnken
04-14-2016 12:34 PM
