Trunk not seating - doors unable to be locked
Old 10-10-2008 | 07:19 PM
christo's Avatar
Default RE: Trunk not seating - doors unable to be locked
Hey Ann welcome to the forum. I am not to familiar with your vehicle but if I recall my Lincoln had the same problem. I found the the motor in the lock has gone south and needed replacement. I am hoping there is an easy fix and this is just something characteristic to the vehicle that is not serious. "IF" it does need replacement there should just be a couple screws and a wire, I would imagine getting the beauty cover off the inside of the trunk would be the hard part. Good Luck!
Some else should be around shortly that might know better.
Old 10-11-2008 | 07:04 AM
christo's Avatar
I believe the motor and the mechanism are 1 piece.
Old 10-12-2008 | 03:15 PM
oldmots's Avatar
Just as a reminder, it's a good idea to check fuses and relays before opening things up, it could save some time.
99xk8guy
06-05-2023 06:28 AM
aholbro1
08-05-2021 05:02 AM
dsnyder586
04-04-2019 02:38 PM
GordoCatCar
01-02-2017 01:10 PM
XJsc-guy
11-23-2015 01:56 PM
Quick Reply: Trunk not seating - doors unable to be locked
