Trunk only partly opens
This 04 XJ8 I just got will only release the first part of the sequence on boot lid open command. I have to use the physical key to fully release it. I took out the actuator and messed around with it; nothing seems to be wrong other than it does not pull far enough or long enough to completely yank the little pawl. Has anyone else experienced this? I did not disassemble the solenoid but am not afraid of going there if it will fix it. Thank you.
Once the trunk latch is released the gas struts should raise it about 1/2" then the owner can lift it up manually all the way. If this doesn't happen, you'll have to use the key as the lid has not risen far enough for the latch to let go. All I can say is that I had a similar problem and new struts cured it. Of course your problem may be different.
cyber3d
11-12-2015 05:43 AM
