Turning off adaptive cruise info pls
Searched the forums and learned a lot about this topic but still a little confused. I am looking at a 05 XJR and was told the radar module (at bumper) needs replacing. From the forum, I understand it can be turned off until I find a replacement. Not a cruise control fan so it is really a non-issue but I don't want the warning on the dash.
My local jag mechanic said he can't do it. Is this something a dealership has to do? How much would be a fair price to pay to have this done? I will be picking the car up in L.A. and driving to Oklahoma so can stop anywhere on the route to have it done.
Thanks for advice in advance!
Looking at the wiring diagram - its in the CAN network, it communicates with ECM, Instrument Pack, ABS/Dynamic Stability, and Trans module. Trying to disconnect it may disrupt system and display warning on dash.
There are 2 fuses, but 1 supplies power to multiple items on the car. You can try taking out fuse 27 in the passenger compartment fuse to see if this will disable it.
Otherwise, you can still turn it off by using the switch on the dash.
"You can disable the ACC using the SDD/Mongoose
Set it to ACC "Not Fitted". This will bypass the ACC module
Scans will still find it tough so you may need to take the plug out of the module and radar
This will take you back to STD cruise control"
I take it as you need the SDD/mongoose and account at TOPIx for the software to turn it off. Then the ECM takes over as standard cruise control.
Guess I am looking for someone who can do this and a cost associated.
I never use cruise control so that seems like a lot to throw away on something to make a light go off on the dash.
Go on ebay, find a used one for a few hundred bucks with a warranty (at least long enough to hook it up and make sure it works) and fix it! That price is nuts and sounds like a dealer price. You have an 05, so it should be the more common ACC module that was used from 05-09 in XJ's, 05-?? XK's and maybe even some of the newer XF's and XJ's (someone would have to correct me on this as to when they exactly when to the next gen system in the new models). The other option is take it apart and try to fix it!
I bought my 05 SV8 without the ACC working (can get a better price because of the issue) and looked into doing as you thought, turn it off in the car config. That was just too much of a hassel. So, I took the module apart and found two bad pins internally (my thread on it is on the site somewhere) and replaced them. That was a few years ago and it is working perfect to this day. My second choice was getting a used radar module on ebay (had found one with warranty for $150).
Adaptive cruise is the best thing ever! I love it for really long road trips. I can drive for hours without ever touching the gas pedal!
Eagle180 (03-23-2018)
marron400
12-31-2017 10:58 AM
stham
05-18-2017 09:44 AM
RiverDog
12-10-2013 01:27 AM
