Unable to hear caller thru Bluetooth
Have a 2005 XJ8L was taking thru Bluetooth in the car. Heard a small pop. Then I was unable to hear the person I was talking to. They are able to hear me I have paired the phone again but still cant hear the person I am talking to. I do have the touchscreen if that matters. What can be the problem
I seem to recall my DTC reader called out specific speakers in the past. You'll need to be able to read Jaguar specific codes and in my case I have the premium audio system (amp in trunk, separate from head-unit). If you do not have a code reader you're 'shooting in the dark.' You can search the forum for code reader recommendations. I have a Foxwell NT but there are other forum members whom have also had good experience with other code readers.
Also search the forum for your speaker issue: https://www.jaguarforums.com/forum/x...-xj8vp-198361/ addresses a common issue with solder joint failure to the OEM speakers. I have performed this repair myself to resuscitate inoperative speakers. You might try this to bring the speakers back. But I still recommend getting a code reader.
Best Regards, William
3labsdaddy (05-08-2019)
1LoudVP
01-23-2014 03:45 PM
snafubar
03-20-2012 12:13 PM
