Underbody Brake Lines (post-Recall) - Please Check
@Rancheroguy that was going to be my original approach too, unfortunately for me I found that the corrosion had spread through the entire line section, and there is nowhere that I can get a sufficiently stable line to flare.
Having said that, SNG Barrett sells the replacement molded line for about $30 plus shipping (it is light, but large). To replace the line as one unit you would need to drop the exhaust, drive shaft and fuel tank. However, I think there is a way to cut the molded line into 3 sections and install each separately. I have to admit that I have not tried this yet, but that's where my current thinking is.
I believe the line is 3/16" flared to metric fittings. I can't remember where I read that though.
As soon as I determine the line specs I plan on buying a 25 ft. line/fitting "kit" and then going from there. I do not plan on dropping the fuel tank if I can help it since I can't get in my garage right now. There are so many types of flares being used now it is hard to guess what Jaguar used. (I can probably look to see what is the most difficult and expensive then assume that is what I have. I should only have to match Jaguar's flares a couple of times. (Double 37 or 45 degree, mushroom, bubble, inverted?)
If I had only checked everything and ignored the work order showing the recall work being done I would have saved some headache. I honestly do not like having so much under the car covered by shields and out of sight. It makes it difficult to do routine inspections. Even if the pad is removed from the shield there is a place for debris and moisture to sit and cause problems. I know I probably have black widows under there. Too bad spider silk doesn't seal leaks.
I had to replace both the rear lines on my sons P38 RR, and purchased them from Land Rover. These both ran front to back with multiple jogs. I found an area to cut, flair and splice to make the install much easier. This also ensured I had the correct END fittings to the front and the calipers. Splices were just normal fittings from auto part store. If your original end fittings are in good shape, just buy a coil of nc tubing and bend your own. In my case the ends were beyond salvageable (rusted beyond repair)
Well I should have checked my. Rear line let go returning home last night. Looked under the car today and there is a puddle by the right rear wheel. Ordered universal line with an assortment of fittings from Summit Racing. It should arrive next week (on back order and Covid shortages mean they won't know delivery times until next week sometime). I will get the car up in the air and start removing lines while I'm waiting. I'll try to post a summary of the repair.
remove lines separately feed new ones through the middle and bend to fit. use extensions to put the clips in that go along the tank
What are "real lines"?
I've ordered
https://www.summitracing.com/parts/URR-BR-EZ316
a little pricey but it has extra fittings and more tubing than I will need so I'll save the rest for future jobs.
I've ordered
GordoCatCar
02-12-2010 09:25 PM
