unlocking driver door sometimes fails
Old 02-14-2018 | 04:11 PM
nebelfuerst's Avatar
Default unlocking driver door sometimes fails
I love my XJ, although I don't drive it often in winter time.
When unlocking my XJ by the fob, the driver door sometimes doesn't unlock.
I have to use the key to unlock.
Some oil attached to the visible, moving parts didn't help.
Is there a way to diagnose this issue further without disassembling the whole door ?
Old 02-14-2018 | 04:34 PM
meirion1's Avatar
It sounds like a problem with the micro switch in the actuator.
I have had this problem and was able to replace the micro switch but in your
case the best repair might be to replace the actuator.
I repaired a rear door also I had a problem with the driver's door but that went away
believe it or not!
The actuator is stamped FORD and an used Ford actuator will fit but you have to get
the right one ie ex Ford Mondeo.
I suggest you search this forum for details and pics (I use google) eg
https://www.google.com.au/search?q=j...N6Hr8AedqprgCw
https://www.google.com.au/search?q=j...w=1708&bih=834
Your Jag is 10.2003 mine is 11.2003!
Old 02-16-2018 | 12:05 PM
Thanks a lot for the useful links.
If the weather gets warmer, I'll try to open the door to get this fixed.
I'll tell my XJ from your self healing story, maybe by door will heal like yours did. ;-)
NTL1991
XJ40 ( XJ81 )
01-23-2016 07:05 AM
jmann324
07-03-2015 09:58 AM
robertjag
04-07-2013 11:36 AM
Dan Bennett
03-07-2013 11:28 AM
iownme
06-25-2011 03:26 AM
Quick Reply: unlocking driver door sometimes fails
