Unreliable Jaguar electronics...
...I NEVER WOULD HAVE GUESSED! This is getting ridiculous. I have a 2005 Jaguar XJR, and am having nothing but problems with everything electrical. It seems that they have not improved upon their terrible reputation. I now have no blower in the cabin, I have no radio/DVD player, and I occasionally have navigation/centre console screen. It only turns on when it feels like it, and when it is off, the backlit buttons around it are dim/stuttering. Jaguar has told me that the radio issue is the AMP itself, however if the amp was bad, wouldnt it not work all the time? It comes and goes, sometimes at full prowess, others the console does not even recognize that it is there. They say the blower motor is probably the control unit, however I do not with to drop the $450 to fix that, when the centre console itself does not work, how do I know it isnt something else? I'm beginning to hate Jaguar -_- Any help?
I have taken it to the dealer a few times, they are great, but i think all they check is the system codes. I have a drainage problem in the trunk causing it to fill with water. I am about to try to change out every fuse for new ones, maybe they got a little corrosion from being in the damp area? Jaguar keeps clearing out the codes, but the problems keep coming back. The radio on/off has been a problem since I bought the car, but after they cleared them the first time it worked again for a few months. Then it stopped, then worked again out of nowhere, now doesnt again. Also, the screen/display issue JUST started happening yesterday, but it does seem like it is a power issue since it doesnt even have enough voltage to completely light up the backlit buttons. The cabin blower has been off for quite some time, but it did originally work. The thing is, i did not do anything to the car directly prior to these issues, I just drove it normally to and from work/school...
Received 2,193 Likes
Hmmm sounds like you just have 2 problems to me. Yes you need a blower control module aka resistor pack. The 1 for an ax8 is cheaper and while diff parts number works fine for a couple hundred less. And yes if the amp is internally loosing its d2b fibre optic wake up signal. The whole nav/entertainment system wont come up ecause they too wont get their signal. (think old style christmas lights in series) nothing really out of the ordinary for failure on a 7yr old car that hasnt been seen before. Besides blame ford, its their system which was a huge reliablity jump for jag in electronics. And the amp is made in china just like all the other suto manufacturers systems. Nothing new there
Mine drifts on the highway in high winds too, surprised me the first time it happened
I am used to it now; it doesn't dive into the ditch, anyway !!
