Upper A arm/wishbone
The ball joints are not available from Jaguar, but might be around on the 'net. If you can find them, you need an accurate mandrel to press out/press in the old and new balljoint. Boiling water poured over the wishbone near the ball joint will be beneficial in allowing an easy press out/in, due to the large coefficient of expansion of aluminium.
On my car there are two transparent boots top and bottom of the rod fixing at the outer end by the brake disc, but what there is at the other end, I don't know, but here's a pic of the assembly. Looks like boots both ends to me.
![](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/27319-upper-arm-wishbone-no12620_c2c36985.gif?dateline=1355002937)
However, this doesn't solve your front upper wishbone problem ! I would repeat my advice - look for a used one to see if you can reuse the boot. The wishbones here in the UK from one internet supplier cost about £165 before tax/postage. For that money you get 1 x balljoint, 2 x inner bushes, and the wishbone itself, an aluminium forging. Its not a bad price frankly. Another UK supplier wants £272 and another £279 !! I am not sure where the difference comes from. Of course if you need both it gets expensive. DO be aware that this kind of thing, (non-repairable assemblies) are in widespread use in the auto industry, its not just Jaguar.
FS[MidWest]: 2001 Supercharged Vanden Plas
Col. Sandurz
09-28-2015 07:29 PM
Camnelson324
09-27-2015 08:48 AM
