URO Parts - Engine Mounts Purchased
Hello Everyone,
Finally purchased the mounts last night and I now prepare to replace the sway bar bushings as well control arm links (Lemforder). Has anyone replaced their engine mounts with the below? And if so, thoughts??
Parts Ordered
2008 Jaguar Vanden Plas Engine Mount Price:$119.73 Qty: 2 Part #: C2C31128
Parts Ordered
My experience is URO is substandard. Every URO part I have purchased has prematurely failed. Just my experience. I would never put a URO part in an area that is not easy to swap out. Spend the money and buy OEM, or if you can cross reference an actual Ford part those are usually the same. It is not worth the labor to go cheap on suspension parts even if you like doing it twice.
hisport (02-12-2021)
