using the J gate shifter
Does anyone here actually use the left hand side of the J gate shifter?
Having driven manual/standard/stick most of my life I feel the need to get engaged with the gears. I really miss having a clutch! However, every now and then I shift the gears myself - especially if sat next to a beemer at the traffic light!
One question I have -how come there is no first gear? And does the car go through first to get to second when shifting "manually?" I tend to think it does.
Also, are there any advantages or disadvantages to "shifting manually" that those more wise than me in jag lore might know?
someguywithajag (11-14-2016)
I have found shifting manually using the J gate for rapid overtaking is better all round, because you can pre-select a low gear before commencing the overtake, whereas if you rely on the box control, there is always a pause after you have pressed on the gas pedal until it decides what gear it is going to allow you to use, so yes, there is benefit.
Of course on our twisty and narrow English roads there is never a great deal of road space for overtaking, so one has to make maximum use of what is available and move quickly.
Always. ^
I use the selector for overtaking, if I need to do so, quickly.
I suspect the down side of using it as you would a manual geared car, is more wear in the gear box and engine, by not driving at revs optimized by the computers.
Of course I have no data to back up my suspicion.
Received 2,266 Likes
The J selector simply limits the highest gear that the transmission can select. It does not force the transmission to stay in the selected gear continuously.
n2audio
17
10-09-2015 10:53 PM
