Valley Coolant Hose and parts
Well, my 10 YO cat has become a little incontinent and dropped its cooling fluid.
It seems to be be dripping from the back and an inspection seems to suggest that it is the hose under the supercharger.
I have recently had a puffy radiator hose and the expansion tank replaced.
I plan on pulling the SC etc off and seen many links on this but no list of parts.
As I understand it from some of the links, the parts required are:
- Heater Feed Hose
- Return Hose
- EGR gasket?
- TB gasket
- TB Elbow gasket
- SC outlet duct gasket
Valley Hose parts list
Have compiled the following to try and have another complete thread.
PART# QTY Description
AJ89746 1 Heater TB Hose ---> Leaks New version
AJ88507 1 Heater TB Hose
These are the two hoses that tend to leak.
Peripheral seals and gaskets. Some 'could' be reused.
AJ86892 2 Blower to IC duct seal
NCC7735BA 1 SEAL SC OUTLET
AJ83292 1 Induction to SC Gasket
C2C11477 1 Thermostat tower Oring seal
C2C17430 1 Throttle Body Gasket
AJ88559 2 EGR Valve gasket
AJ88560 1 EGR Valve gasket
AJ811758 1 Coolant EGR hose
AJ88514 1 Coolant EGR hose
Will try and photograph and document for reference.
04XJR (07-17-2023)
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
