Vanden Plas Front Grille
I wanted to try the mesh front grille, so I went for a 48"x12" sheet that I had to cut and fit:
It's a good bit less expensive than getting something pre-cut, but if you're not a craftsman and don't have a lot of patience I wouldn't recommend it as being worth the savings.
It was very challenging getting the right fit around the plastic tabs because of the nature of the aluminum mesh. I'm satisfied. See what you think...
lower grill
Thanks Kbeachy.. I actually bought the lower grill on ebay. Top was there already; bit there are just 2 screws to undo, pop the "grill boxes" out (I can't think of what they're called now) haha; bit the black pieces pop out, & the lower mesh I purchased was/is pre-cut to got of course. Screw it into the housing that holds the fog lights along with 2 more you make, & voila!..
rusty37
04-05-2020 07:40 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
1964Daimler
09-09-2015 11:28 AM
