Vanden Plas seats in an xj8?
Hello, i have a 2004 xj8 and i found the same color seats from a vanden plas. i was wondering how easy they can be switched out and if the electronics are the same.. in the description its says fits xj8.. any problems i could run into? the description also says: 'seat switch not included' if my current seats are 100% intact and function perfectly, all electronic motions work, do i need a seat switch or is the old one ample? any help/comments with this conversion would be appreciated.. thanks
restorsc (05-10-2017)
Hi Bigvettefreak,
Did you used the XJ8 modules under the seat? or the one of the VandenPlas? I am waiting a front seat from VanderPlast (without modules, and without button, only the track and motors) the XJ8 is a 2 ways the VandenPlast 16 ways.... did you used a 12 or 16 ways buttons? Did you reprogrammed the modules?
Thank for your help!
Regards
Regards
