"Vehicle too low" after R&R of upper a-arm
I just completed the R&R of the upper control arm on my 04 XJR which requires removal of the air spring. As instructed, I removed the 12mm air line to let air bleed out. After reassembly, the car sits low on the side that was repaired and gives "Vehicle too low" message. I have checked for leaks and there aren't any, cycled the battery for good measure - no change. Really bummed as the car didn't have any issues prior to repair. Any suggestions?
THX
Franck
THX
Franck
Thanks for the suggestion, though prior to pulling the spring I disconnected the sensor mount from the lower control arm so that I would not over extend it's range.... I have also checked the 3 fuses that are related to the air suspension and all ok
jagbuff (02-16-2013)
He is right! Ended up getting frustrated and pulled the car off the lift, fortunately by the time I pulled out of the driveway it had decided to "raise from the dead", so that's the good news the bad news is that clonking noise is still there!
Camnelson324
09-27-2015 08:48 AM
