vehicle too low - any way to check PSI?
Last Sunday, which was a little cooler than usual, my wife was preparing to head for her church and got a "vehicle too low" fault and came back in to ask what she should do. I restarted the engine and I drove the SV8 around our loop road and the fault remained so she took a different car. later in the day (and warmer) I started it and the VTL fault did not appear.
About half the times I drive it, I get an "air suspension fault" message after driving awhile, but I haven't yet gotten the software for my Mongoose to work so I can't check the body or chassis codes. When I have checked the ride height, it is within spec for all wheels. The front air shocks are relatively new Arnott units and the rear shocks are probably OEM but I don't know for sure.
So... Is it likely I am in need of a new piston ring from bagpipingandy before the weather turns cooler? Is there any easy way to check the pressure in the air suspension system to see if it is reaching the 220 PSI required?
The o ring kit would be my first choice for sure. The process of carrying out the oring change is well documented.
Then be watchful for the 30f weather because that's when you find out the rubber grommets are shrinking and you get the dreaded faults.
Then its time to do all the connections and checks for leaks everywhere.
The following 2 users liked this post by trosty:
Don B (10-22-2015),
philwarner (10-22-2015)
Received 9,010 Likes
Don B (10-22-2015)
Received 13,085 Likes
Phil,
+2 on trosty's and Jim's advice. At 130K you definitely need to replace the compressor piston ring seal with bagpipingandy's kit. In addition to Andy's video, I have a phototutorial specifically for the X350 in my photo albums at the link in my signature.
The O-rings on the air hose fittings should be checked by spritzing them with soapy water, taking care not to get water on the electrical connector for the CATS solenoids on the tops of the shocks or the pressure sensor on the valve block. On our '04, I have tracked down the cold weather leak to the front right air spring top seal, which is not replaceable, but replacing the compressor piston ring has mostly eliminated the Vehicle Too Low problem.
Cheers,
Don
Cheers,
Don
philwarner (10-23-2015)
Phil,
The O-rings on the air hose fittings should be checked by spritzing them with soapy water, taking care not to get water on the electrical connector for the CATS solenoids on the tops of the shocks or the pressure sensor on the valve block. On our '04, I have tracked down the cold weather leak to the front right air spring top seal, which is not replaceable, but replacing the compressor piston ring has mostly eliminated the Vehicle Too Low problem. Cheers, Don
BTW, I received my eBay 2003 S-type used engine cover today and it went right on the SV8. Whew! One more thing checked off the list.
Hey Phil. You might give this a try from a very generous forum member.
https://www.jaguarforums.com/forum/x...s-loan-126934/
Don B (10-23-2015)
Phil,
You don't have to remove the front bumper cover to access the air compressor. You access it from below, so you just remove the plastic splash cover along the bottom of the bumper.
Here are the links to my photos. Most folks don't replace the dessicant in the air dryer like I did, but since mhamilton has some leftover dessicant beads that he's making available cheap you might want to consider it since you should open the air dryer to check for corrosion anyway.
Welcome to Jag-lovers - Members Photo Viewing Page
Cheers,
Don
Sean W (10-23-2015)
philwarner
10-02-2015 11:23 AM
dmatthewman
09-30-2015 10:10 AM
driver safz
09-26-2015 06:01 AM
