Vehicle too low - replace both shocks or just one?
Greetings. This morning, my 2005 VDP's front end was almost sitting on the tires. Upon starting I could hear air rushing out of the drivers side wheel well. I imagine the shock went. Kinda funny - from what I'm reading, 7 years is the average. Taking it to mechanic soon, but he only recommended replacing just that one. I expected to replace both. Will cost about $600 per side. What do you guys say? Will likely trailer it, & mechanic is about 35 miles away. Would you guys replace both fronts or just the one? Thanks.
I used to be in charge of quality engineering for an OE shock and strut manufacturer. I can tell you that over time the degredation in performance from when a shock is new to when it has been used for hundreds of thousands of miles or many many years is minimal. The only real reason for shocks to need to be replaced is because they start leaking. I will never replace shocks based on mileage. I will always wait until they fail. With that in mind, you do not need to replace in pairs.
In fact, I will tell you a little secret in the business. Aftermarket and Service parts are shipped in different batches from the standard parts going to the factory for installation on new cars. Things that don't quite meet the factory specs are many times held to the side to be shipped to aftermarket and service warehouses rather than becoming scrap. In other words, even OE aftermarket parts are not neccesarily as good as what was sent to the factory.
Now the airbag is a different story. Since these cars have the shock and air spring combined there may be some good thought behind changing out both sides. I am not sure how the air spring performace changes over time and mileage. I could imagine that as the rubber wears out the pressure needed to keep ride height could change and having a mismatched set could cause ride feel issues. Anyone have any insight on this theory.
A couple of years ago the rt. ft. air shock on my 05 XJR XJR started leaking bad on cold nights. I replaced just that one with an Arnott rebuild with good results.
Last week I replaced the blown adaptive rt. ft. shock on my 07 XK with good results. The dealer did recommend replacement in pairs and refused to do the work with just one. So I found a shock/strut off a car like mine with similar miles and did the work myself. Saved approx $1,000 in the process. Again, good results. Rt. ft. shocks do take a beating. I'm just so proud.
This is Jaguar's view from a TSB issued in 2003:
Summary
B204-03: This Technical Bulletin has been issued to inform the dealer network that the policy of replacing shock absorbers in pairs after the remaining shock absorber on the same axle has covered more than 25,000 miles is now rescinded.
Action Replacement of Shock Absorbers
The policy of replacing shock absorbers has been revised as follows:
During the warranty life of the vehicle the failed part only will be changed using the following criteria:
Summary
- Only one shock absorber across an axle exhibits a defect.
- The part number of the replacement shock absorber is identical to the one being removed.
- The vehicle has completed less than 60,000 miles (96,000 kilometers).
Brutal (07-26-2012)
Received 1,192 Likes
Great... I'm looking at an aged work order (Oct 2007) from my local dealer in which the failed shock absorber was replaced... at my cost. At the time I had 57,000 km on the car.
I had Select Edition and if memory serves me correctly; when questioned I was told they were regarded likes brakes: a regular service item. Live and Learn. Thanks for the TSB though, at that time I didn't think of researching it any further.
Received 2,194 Likes
great... I'm looking at an aged work order (oct 2007) from my local dealer in which the failed shock absorber was replaced... At my cost. At the time i had 57,000 km on the car.
I had select edition and if memory serves me correctly; when questioned i was told they were regarded likes brakes: A regular service item. Live and learn. Thanks for the tsb though, at that time i didn't think of researching it any further.
back then select did not cover air springs and only recently was this changed to cover air springs depending on the failure. If the shock inside the air spring leaks its not covered. Leak air, yes. No extended warranty company out there covers shocks, they are considered expendable like hoses, belts, etc
Expendable at $650+??
Do i make the rules? no! Go buy a new one from jaguar from $1000-1400. cost does not determine expendabilty
I have a new oem for $625 with free shipping and several good used ones that are leak checked too. for $200
Youre driving a $60,000 car, the parts do not get cheaper as the car does
BrentGardner
28
04-26-2024 03:08 AM
Fraser Mitchell
10-01-2015 04:06 AM
