Vibration
Could also be warped rotors. Warped rotors don't necessarily pull when applying brakes, more of a slow bounce or grab and release. But you would feel that in the pedal and in your seat. Vibrations felt at the steering wheel can also be worn out front hubs, failing air springs, motor mounts or a damaged caliper.
Bill It is all here thanks to Don:
https://www.jaguarforums.com/forum/x...ration-215663/
Not an x350 but very similar
I have been trying to source if there's a problem with my bearings . The rear wheels got a slight temperature near the center , more than handwarm (driving constantly 100km/h outside temp freezing) snd felt something is not right. Had no vibration though . I decided to make my mecanic change the bearings and the brakepads all round . He found one guiding pin on the caliper stuck on both sides at the rear.
causing the pads to not being in correct position warming up the brakediscs and the wheel center area
I HAD STUCK GUIDING PINS ALREADY ON THE FRONT 2 YEARS AGO
