Vibration/sound at stop
When I bring the car to a stop, while in gear, there is a vibration and associated sound coming from the car. If I put the car in neutral/park the sound/vibration goes away. It used to be less prominent if the climate control was turned off, but now that doesn't seem to matter. Oh, and it isn't "all the time", just comes and goes.
Any ideas?
Pulley? Belt? Transmission?
Other then the noise/vibration the car functions perfectly.
Any ideas?
No warning messages or fault codes means you're back to basics tracking this down. From what you say the vibration is there after the car has stopped, is this the case ? By disappearing when the trans is in neutral indicates something not right in the torque converter, or transmission, as by putting the car into gear, a load is being put on the torque converter, and also the transmission. Sometimes all these things are cured by a reload of the TCM software. I know it sounds stupid, but both my trans faults were cured by this; it's the modern car syndrome I'm afraid.
Never had any probs with the Borg-Warner 66 on my old '80 XJ6 !!
I also noticed today that if at a stop in gear, the noise get much loader if I turn the steering wheel, but again it all goes away when I put it in neutral or park. It also makes the noise in reverse.
Someone suggested bad mounts as another possibility.
Not sure where you got that idea, it makes the most sense to me. I just have not had an opportunity to confirm it.
I have also noticed a noise when I am at a dead stop, in gear and then move the front wheels about 1/4 turn of the steering wheel and the car makes a similar sound but louder.
ah I see, I read this one before your thread. Funny thing, the last several days it has been mostly in remission. Only noticed it a couple of times. The steering noise also only happens when stopped. Even slowly moving (with windows open) and turning the wheel doesn't produce the noise.
Yes, stopped, in gear, foot on the brake. You can't hear it or feel it when the car is in motion. It could still be there, but masked by other things. Put it in neutral and it all goes away.
Reloading TCM seems like a cheap date compared to replacing parts. This has gotten steadily worse the last several days.
MIne to
Any ideas?
Any ideas?
Then when pulling off very slowly, like from 1st to 2nd it vibrates/shakes a little.
Id like to try the TCM Program update too before i start any flushing/Parts.
Is there a way to DIY the upload, if so where would you get the Software from?.
Mike
How did you go about reloading the TCM on your car?
was it a dealship job or can it be done by your self.
Please write back.
Mike
@Fraser Mitchell.
Please write back.
Mike
Please write back.
Mike
PlatinumJag
20
10-02-2020 02:23 PM
kabs3012
09-12-2015 10:40 AM
