Visiting a drag strip in an XJR...
#41
yes Patrick that would work, but if youre cutting off the silencer flat but not even with the tube.Leave a boss there. Why not plastic weld a new piece in there flat and mount the nozzle there? Also the units I did used the factory washer bottle and mounted and screened inlet into it to the pump. Then you dont have to worry about additional bottle and you have a washer level sensor to tell you when youre low
The meth kit arrives today but I will not have time to install it until the weekend after next. I have also ordered a new OEM air tract just in case I mess up/I blow up the car and have to take it in for service.
#42
Received 2,191 Likes
See the flat on the end of the silencer? I would cut off the silencer, then cut anothe couple inches off the move that end cap in close to the air tube itself and plastic weld the silencer back to together with the tube. Then drill and mount the nozzle into the flat on the end of the "shortened" silencer. The nozzle is metal so your not going to plastic weld that. But just shortening the silencer so it will give you a flat surface to mount the nozzle, and will be closer to the air flow tract through the tube...kapish?
Ive also seen people use the smaller bottle for washer fluid and its sytem, but use the much larger factory washer reservoir for meth injection. This way you have more capacity and a level sensor. Plus when the smaller aftermarket bottle runs out of washer fluid, youll know, itll quit squirting
about as usefull as the message warning you of "low outside temperature" no shyt i just got in the car from outside!!!
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
#43
about as usefull as the message warning you of "low outside temperature" no shyt i just got in the car from outside!!!![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
Brutal, in my research, I have found that a water/methanol injection system on an untuned motor will generally cause a loss in power. As you probably know, there are very few companies who can even tune Jaguars as is, let alone create a custom map for a water/meth kit. I was planning on running this kit untuned. In your experience, do you think that I will actually lose power at the end of the day?
I understand the ECU in my XJR is one that uses a learning algorithm to adjust the air/fuel ratio according to real-time conditions. Hopefully the computer will be able to compensate for the richness that will be caused by the water/meth kit.
#44
I use the factory washer resevoir, the resevoir is 7 liters & has a built in low level sensor. The resevoirs they supply would be very difficult to mount & remember the pump has to be mounted by the resevoir as it is gravity fed. The last thig you want is to run the pump dry. I can feel the increase in power with my system activated, the charge temp in being lowered & the air density is increased. You will be quite please with the system. I recomend it to anyone with a supercharged car.
#46
That will definitely be an interesting race! Let us know how it goes! When will you be going to the track? My next planned date is May 1st.
#49
If this is the case, then hopefully I can see a gain in power as well!
#50
#51
well i started calling him 2 hours before the track was suppose to open and he never answered or called me back to confirm meeting me at the track per our discussion earlier this week. I think he's dodging me for some reason (lol) dont know why hell he should have me coverd. I have been asking him to race me for a year now and its always an excuse.
#53
let us know how you do. I know mike from eurotoys and a bunch of guys from his car club are going to byron as well. I already had plans to go to GLD with some friends today for import wars, but i'm not running...too expensive there, sometime this year I'll run at byron. I want to be right were you are, 12.9 territory
#54
car ran really good went 12.77 @106.99 and 12.82 @106.63 yea saw mike and all the guys from the club we all had a great time.
#55
#57
I was going to test out an octane booster my next time out! I figured I'd put fresh gas in and the octane booster at the same time. Drive to the track on this mix to let the ECU figure things out. Hopefully it would make a difference!
#59
#60
finally got the video from the other day.
<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/tAOJXeYq9Ks...</param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/tAOJXeYq9Ks&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
