Voice Module part Number
I want to add Jaguar Voice commands to my 2006 X350 (Super V8) but want to make sure that I get the correct part. I have found what seems to be the right one. It has the following numbers:
Part Number 1R8F-14B292-HB
Jaguar Part XRB30427
VACM Voice Module
Is this the correct part??
Also, is it "plug-n-play" or will I need wiring. My vehicle has every other option (Navigation, rear seat multimedia system with TVs, bluetooth phone, Sirius radio, etc.). Where does it plug in?
I know that similar questions about adding a Jaguar Voice module have been asked on the forum, but I cannot find any references to this particular question. Please forgive me if I am bothering anyone with an old question. I did spend a lot of time looking for the answer.
Many thanks!
VACM Voice Module
Many thanks!
Did you see these threads?
https://www.jaguarforums.com/forum/a...nstall-139410/
https://www.jaguarforums.com/forum/x...e-84450/page2/
It's plug and play. I retro'd it in our STR and SV8. Get one, any one, and plug it in. the only issue will be it will be programmed for the car it came from. For example, both the VCAM's I bought for each of the cars came from the UK (super cheap) and they don't recognize the command for AM radio (don't seem to have that over there!). Also, I retro'd the phone in both the cars as well, but the STR doesn't have the commands, but the SV8 does. Minor annoyance, but as far as I know, they can just be reprogrammed (somewhere in IDS) with a VCM. I'm actually in the process of doing this soon as I just got my hands on a VCM. All this being said, they have been in the cars for years, and it's never been an issue. Actually, I rarely use the voice commands. Might adjust the temp, or cancel the NAV route now and then, but that's all. Still, it's a neat feature to have and passengers seem to find it cool.
Just to add, it doesn't matter what car it comes from. The VCAM in the S-type is from an XJ and the one in the XJ is from an S-type! (guess I should switch them around to be 'Correct', eh!)
Sounds good. So, this unit will work?
VACM Voice Module
How about the mic. Since I have bluetooth phone that works from both the front seat and the rear (via multimedia console), I would think that there are already two mics in the car (one for the driver and one for the rear). But, if I have only one in the front, will I have to install another mic in the rear?
Also, was your '05 SV8 already wired for this or did you need to add an additional harness or other wiring? (Mine is '06 SV8). If so, what did you need?
Like you, I suspect that I will not use it a lot. But -- assuming that I don't spend a lot to get it working -- it will be great fun. As you say, the passengers will love it.
VACM Voice Module
That one will work, but just a heads up, I paid a whopping 20 pounds for one of my modules, and 50 pounds for the other. You can find them for real cheap if you look around and not worry about perfect matching spec. And if it is coming from the UK (like mine did), even if it is perfectly spec'd to your car, it still won't recognize AM radio.
As for the mic, it'll work fine. If you have the rear mics too, they should be up near the grab handles in the rear. If you only have the front one, it is a bit involved to install the rear ones. I am planning on installing them myself, and I believe the headliner needs to be dropped and the rear seats removed to run the new harness. I wouldn't worry too much about it right now. The other thing is, just because you have the controls for the phone in the rear (mine does too), doesn't mean you have the 4-zone voice control/phone setup. All the rear control packs have the buttons for voice and phone, whether you have it or not. I'm pretty sure I can control the phone from the back too, but I don't have the rear mics.
My SV8 actually didn't come from the factory with voice or bluetooth (very odd for a SV8 since they were supposed to have everything). As far as I know, all X350's were wired for everything, just add the modules you need. I had to add the mic up front, but that one is easy.
All this being said, my advice is get the cheapest VCAM you can find and plug it in. It'll work for 99% of the things you would actually use it for. If not, you can just have it reprogrammed.
Deepstuff (03-19-2024)
You said, "
All this being said, my advice is get the cheapest VCAM you can find and plug it in. It'll work for 99% of the things you would actually use it for. If not, you can just have it reprogrammed."
If I need to re-program the unit, how do I do this or where can I have it done?
I answered in your PM, but for anyone else out there here it is:
Programming is done with a VCM and IDS 118.5. A mongoose and new IDS should work, but I'm not sure. Now, Cambo is the expert on this and he is the one I got my knowledge from. He can correct, or confirm, what I'm saying just to make sure!
Be careful of the part number of the voice module you buy, different part numbers for different languages!
2R8F-14B292-AA, -AB, -AC, -AD = US English
2R8F-14B292-BA, -BB, -BC, -BD = British English
2R8F-14B292-HA, -HB, -HC = Australian English
2R8F-14B292-DA, -DB, -DC, -DD = German
Other languages have other suffixes, French = Fx, Spanish = Ex, etc...
I have not had a chance to try a reprogramming to change languages in a module yet, although MagMedia did send me a German one to try changing to English...
For programming work on an X350 (or any Jag that has SCP & ISO networks) I would strongly recommend using a VCM, I definitely do not recommend clone Mongoose/Mangoose, use them at your own risk!
Thanks Cambo and WinterJag.
It looks like the module that I ordered is in Australian English. Does that mean that it has commands that are different from the U.S. English model? Will I have to say "mate" after every command or drink a Foster's before driving??![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Seriously, what is the difference between the Australian and the U.S. model? Also, can it be reprogrammed to U.S. English??
Guess I will have to throw a shrimp on the barbie
. or the manifold..
Someone mentioned that the British version doesn't recognize the AM radio. Any such issues with the Aussie version?
Sorry. Posted this twice and can't figure out how to delete one of them
. or the manifold..
Well, as to the voice thing, yes, you need to make it the right language! Like Cambo (who knows all!) my voice modules from the UK have that lovely British accent! I would guess its the same for the Aussie one. And I can confirm the UK ones have no trouble understanding plain old Canadian english (although I guess we still have some Brit in it).
Ben: Hmm, that's odd about the Am radio. Both our cars only recognize commands for MW (medium wave?) and the head unit in the wife's STR is also from the UK and it doesn't have AM, only MW and LW. I know I can just reprogram them, but its still odd since you have confirmed you have AM across the pond (in the other direction!).
What is interesting is that I replaced the cassette player a long time ago with the single slot CD player, but the voice module doesn't seem to know about that and just gives me the voice help for 'TAPE' related commands. There must be some way to configure the voice module with which options have been fitted to the car.
Ben
