Water in the car.
TSB tells you how to address water ingress spots. The rear door seal is a known issue along with the trunk area.
Marine grade clear sealant works good to rectify. Had the same issue on my previous 04 XJ8. Took care of all areas on TSB and inside was bone dry after 2" of rain.
Finally, remove the drivers seat and trim and vacuum up excess water collected in carpet and foam.
Timothy
05-16-2012 07:14 PM
