Water in footwell 2005 XJ8 VDP
Hello.
I've owned my 2005 XJ8 VDP for about three years and last year the rear offside passenger footwell (LHD car) was soaked. When I removed the plush mat, water poured from it and it took my wet/dry vacuum to get the water out of the footwell. This was the only area that was wet. There was no sign of water in the headliner or anywhere else in the car. I thought it might be the sunroof and took a hose and soaked the car but no water leaked in. I've checked and cleaned the door and trunk seals and all appears well.
Last Saturday we had 8 inches of snow and when I went to used the car yesterday, after the snow had melted, I found the plush mat and the carpet wet in the same rear footwell but not as soaked as before.
Just now, I've taken the hose and run it around the door seals, trunk seal and sunroof and no water got in. I'm stumped and would appreciate and guidance as to the cause and how to fix.
Thanks all.
Stephen
Thanks all.
Stephen
Received 13,425 Likes
Hello.
Thanks all.
Stephen
Thanks all.
Stephen
Pull back the rubber seal for the rear passenger door, get clear marine silicone sealant and fill in the gaps (body) from the top of the door down the side to the floor. Just run your finger down the panel and let the sealant fill in. No need to over do it, just flush.
Give it an hour or so to tack up then put the rubber seal back on.
Look at that TSB on water ingress and check all. I performed all fixes, whether they applied or not and my interior was bone dry ever since.
Also, check sunroof drains (2 rear, 2 front) with a flex wire, also pour hot water very slowly if drains are clear you will see/hear water hitting floor. No hoses! those drain channels cannot hold that much water...
The passenger side is the biggy as if that drain cogs up you will get water ingress in your PCM...
Don B (01-13-2017)
I had the same problem a few years back. It was the sunroof drain. The water only accumulated as I was driving in rain with the sunroof closed. Apparently it got sucked in past the seals and finding one or more drains blocked it migrated to the L rear floor.
Do not attempt to blow out completely clogged drains with compressed air as you risk blowing off the drain tubes from the sunroof assembly and then you got real trouble.
After you get some amount of drain flow with soap and water you can carefully apply compressed air. The drain in my case exited the car in the r rear finder well. The gunk that came out was impressive.
Don B (01-13-2017)
After I wet the drain tube a bit, I use a spline weed wacker line to clean them out by hand. After the bright orange line exits the tube, I attach a drill and SLOWLY spin the line. Sort of like a drain snake. It cleans the sides of the tube, then run some water thu it.
Also if your drain line has come detached, you will know it before you dump water onto your headliner. If the line doesn't exit where it should, don't pour water into the sunroof channel.
