Weatherstripping
OK my friend here is the answer and it will cost you?
NADA!
Roberwil 'steals' from the *******s again!
Just a footnote-the worn bit ended up on the passenger side footwell and I cut some foam which I covered in black insulating tape.
The foam was inserted into both ends of the worn section and was compressible when the door was shut.
Importantly the join was still under the tread plate.
NADA!
Anticitizen (09-05-2013)
edselsouth1
10-04-2012 09:06 PM
edselsouth1
01-02-2012 08:33 PM
