Wet ECM - now won't crank
Went through a drive-through car wash and water got in underneath the windshield on the passenger side and got my ECM box wet.
After removing the ECM, taking it out and drying it with a hair dryer, I replaced it put it back in the car and reconnected it try to start the car. The car still wouldn't start I had to tow it to a local shop.
Is this something that needs to be fixed by replacing the ECM or did I not allowed enough time to dry?
_______________
2004 XJ8
_______________
2004 XJ8
_______________
2004 XJ8
_______________
2004 XJ8
In my case I was pleased to see the somewhat sealed circuit board, and, after blow drying it, resetting the emergency brake, all was well. The only suggestion I have is to clearly check the wire harness connection to ECM. Use some electronic cleaner, and cam it on and off several times. As long as its well connected, and your battery is fully charged, I would expect it to work. Beyond these things I am at a loss on what is still holding you back.
Please check back and let us know how you made out!
I just went over this again, and I hope its what I'm thinking. You didnt describe opening the ecu the way I did when the water came streaming out, and your question about letting it dry enough gives me hope (that you didnt open it) when you do, you will see how its unlikely to dry fully without intervention. The box is mostly empty space besides the pcb, and itsnot designed to vent or drain moisture.
Please get the ECU box open gently, and fully dry the circuit board with a blow dryer - its been a few years so I can't say with certainty how it is sealed, using a gasket or whatever, but I dont recall feeling worried about water ingres, assuming you keep the drain clean!).
Jaguar used good quality components during Ford parentage, and the X350 is a world class effort from a company of their size
at the time, but some packaging choices were less than optimal, this being a prime example. Another one that I fear is ever needing to replace the wiper motor. It requires removing the brake master cylinder!
madijag
09-21-2018 06:59 PM
hunterpedigo
10-29-2015 05:31 PM
