what battery should be used???
Hi everyone,
lately the car has been giving problems with starting with it cranking over and then finally turning over, I did get a DSC warning light then when the car started it went out. But no battery light is coming on and the alternator is working fine, and so is the starter motor, so I suspect that the battery might not have enough juice to start first time.
So need some advice with regard to buying a new battery if needed, as far as i know my jaguar has an original battery in it which is a 95 Ah Battery Cold Cranking 800 Amps which is for a diesel 2.7.
My problem is there are so many to choose from, but what I don't know is which one holds a decent charge for a start up as I suspect that is the issue, as now you have these start/stop batteries.
So need some advice as to what battery to go for I have seen the following:
G3 Varta Blue Dynamic Car Battery 12V 95Ah (595402080) (017 019)
G14 Varta Start-Stop Plus AGM Car Battery 12V 95Ah (595901085)
any help or advice is very much appreciated.
wazdude (06-18-2016)
Hi everyone,
AGM batteries are lead-acid batteries that hold or suspend the electrolyte in a high-absorption micro-glass mat that acts as the separator material between the positive and negative plates. AGM batteries do not emit hydrogen and oxygen externally like flooded lead-acid batteries. Instead, AGMs have an oxygen-recombination chemistry wherein oxygen recombines between the negative and positive plates during discharge and recharge. An AGM battery has a much lower internal resistance than flooded lead-acid batteries therefore allowing a higher recharge acceptance. What’s more, AGM batteries are Valve Regulated Lead Acid (sealed) batteries that do not have an open vent system like flooded lead acid. With their unique internal assembly and physical design, an AGM battery’s vibration resistance is normally high (5 to 10 times that of flooded batteries.)
Similar to flooded batteries, there are differences between AGM batteries. Some AGMs have the common characteristics mentioned previously. These as known as Single Stage AGMs. Other AGM batteries have these same characteristics plus have other attributes. These batteries, referred to as Dual Stage Performance AGMs, feature:
- Higher recharge acceptance characteristics than flooded or Single Stage AGMs. Dual Stage performance AGMs have an even lower internal resistance than other AGMs due to their improved lead purity levels - approximately 99.9 percent pure.
- An improved power capability at extremely low temperatures than their flooded or Single Stage AGM batteries counterparts.
- Three to four times the amount of deep cycles than Single Stage AGMs due to the active material density levels. Unless the AGM battery produces approximately 400 deep cycles to 80 percent depth of discharge (DoD) and/or 600 to 700 cycles at 50 percent DoD, it is not a true deep cycle.
The greatest risk of damage to AGM's is over-charging and over-voltage.
The latest Gel Cell designs are sensitive to charge rates, and require some considerations to alternator regulators, and would not be on my list of candidates.
What do I use in my XJ8? Flooded, non-AGM design.
I use an AGM
Hi everyone,
I have gone to AGM batteries in all our vehicles.
Locating the battery in the boot is AGM friendly, however, voltage regulator in the alternator can lead to over-voltage and over-charge. Also, there is no method of sensing battery temp. AGM's are a great idea, but older technology in charging systems were never designed to deal with this. Long battery cable runs to the boot, can work in your favor though, as voltage drop due to the length can decrease voltage at the terminal.
hi all,
thanks for the info, but still not an easy choice for one to make, so might decide to go for this battery:-
Type 019 Varta Silver Dynamic Car Battery 12V 100Ah CCA 830(Short Code: H3) (Varta DIN: 600 131 080 or 600 402 083).
Just need some views about the higher rating will it effect the car etc as original battery is 95Ah and CCA 800, thoughts appreciated.
Thank you.
Thank you.
hi all,
Thank you.
Thank you.
