What did you do to your X350/X358 today?
Old 04-29-2017, 09:05 AM
BlacXJRcat's Avatar
Originally Posted by JagsteRJX
I only have the two mufflers on the rear, one each bank.
It's loud when accelerating, especially around 2k rpm when cold. Driving at a constant speed you don't hear it much. The sound is a little throaty/raspy, I think it's due to the Xpipe. The rear mufflers may need to be changed to obtain a deeper more beefy V8 sound.
For a minute I thought you were running only the x-pipe and no mufflers in the back and no resonators in the middle.
I have the same setup (with the stock cats). I don't consider mine loud at all. The cabin is too quiet with the windows up. With windows down the supercharger drowns a little the exhaust sound.
Perhaps the 200 cell cats is what makes yours louder.
Thanks for replying.
  #182
Old 04-29-2017, 11:23 AM
BlacXJRcat's Avatar
So I just pulled the trigger and ordered the Mina Performance Package which includes the intake tube, air intake, pulley and exhaust mufflers. Can't hardly wait for it to arrive.
  #183
Old 04-29-2017, 04:25 PM
joeleerj's Avatar
Repaired and re-colored my steering wheel using a kit from the furniture clinic. Ordered a kit to restore the seats.
https://www.furnitureclinic.com
  #184
Old 04-30-2017, 09:26 PM
Brewster411's Avatar
My center console would not open because one of the tabs on the underside of the plastic handle had broken off. I removed it from the car and repaired it today with a little JB Weld. Hopefully it holds up.
  #185
Old 05-01-2017, 10:24 AM
XJ8JR's Avatar
I've got 200 cell cats, x-pipe and the Mina mufflers. Sounds incredible. You get a wonderful startup roar, but stays civilized the rest of the time, until you press the go-pedal (I think of it now as the volume pedal). Very refined at low speeds and while cruising. No drone whatsoever. Sounds great in tunnels and parking garages.
All this on a NA car. I imagine the R will sound even better.
BlacXJRcat (05-01-2017)
  #186
Old 05-01-2017, 10:32 AM
XJ8JR's Avatar
After many lucky years of putting it off, I finally replaced the valley coolant hose this weekend. I feel much better knowing that ticking time bomb has been defused. While I was in there, I took the opportunity to clean and rebuild the fuel injectors, clean the camshaft and map sensors, and replace the knock sensors. Throttle response, especially under load, has definitely improved, due mainly to the new knock sensors I believe.
  #187
Old 05-01-2017, 10:37 AM
BlacXJRcat's Avatar
I am impatiently waiting for the tracking number on my order.
  #188
Old 05-01-2017, 11:18 AM
XJ8JR's Avatar
I forgot to mention I also have the Mina air intake, but any extra noise that may make on its own is drowned out by the exhaust.
On a side note, I wish someone would make a nicer looking intake tube (from MAF to throttle) for the NA engines. The Rs have nice shiny aftermarket ones available, while the rest of us are stuck with the stock black plastic bellows. It probably wouldn't make any real difference, but at least it would look sharp.
  #189
Old 05-04-2017, 02:55 AM
34by151's Avatar
Replaced a faulty ballast in the drivers headlamp
Upgraded H7 high beams to 252W CREE led units
H7 252W CREE LED Headlight KIT High Power Car Beam Bulbs Replace Halogen 25200LM | eBay
Took the car test drive wow big difference in high beam plus the yellow high beam is gone
Replaced the 4 door lock actuators and added logo projectors to the door lamps
2pcs LED Door Projector Car Logo Lights Shadow Lamps No Drill For JAGUAR XJ XJL | eBay
These were a direct replacement for the red lamps in the door skin
Removed the Front fuse box to repair relay 12
Have stripped down the fuse box to the PCB, next step is to separate the 2 boards.
Going to need a bunch of solder wick to do this.
Plan is to replace all the PCB relays
More in the next few days
34by151
The following 4 users liked this post by 34by151:
Panthro (05-14-2017), Untitled (05-04-2017), woox4 (05-05-2017), XJ8JR (05-04-2017)
  #190
Old 05-04-2017, 04:11 AM
Untitled's Avatar
34by151
Thanks, I've been looking for some of these lights for the xj... can you confirm whether the projected image is of the leaper or growler? As pictures on eBay don't show this.
  #191
Old 05-04-2017, 04:51 AM
woox4's Avatar
The following 2 users liked this post by woox4:
jackra_1 (05-11-2017), Untitled (05-04-2017)
  #192
Old 05-04-2017, 05:49 AM
Untitled's Avatar
  #193
Old 05-04-2017, 10:10 AM
garethashenden's Avatar
I had some new wheels and tires put on my XJR today. I went with the Michelin Pilot Sports everyone on here raves about and I got a set of F-Pace wheels. The stock twin 5 spokes are all sorts of bent giving the car a bit of a shake. The ride is transformed and the shake is gone.
Before and After:
  #194
Old 05-04-2017, 01:29 PM
Untitled's Avatar
Before and After:
Looks really smart, wheels suit it a treat
  #195
Old 05-04-2017, 03:12 PM
34by151's Avatar
My ones have the leaper but both leaper and growler are available
34by151
The following 2 users liked this post by 34by151:
  #196
Old 05-11-2017, 03:34 AM
34by151's Avatar
Repaired the engine bay fuse box
Had the headlamps polished and a new UV resin coating applied
Didn't bother to do the headlamps myself. Had a guy come out and do them for $100. Money well spent with the new coating.
Fusebox repair was straight forward but a bit of a pain
After stripping down the fusebox to get the PCB out you find thee are 2 circuit boards that are soldered together with about 50 pins.
I started removing the solder on the pins with solder wick till I found a mate had a desoldering machine. This is just like a regular soldering iron but has a hollow tip. The iron is connected to a vac pump so you just heat up the solder and press the button.
With the PCB apart it was a simple matter of getting new DIN relays and soldering it back together.
I chose to replace all the relays not just the failed one.
All in all repaired for under $100
O2 sensors are now working.
Tomorrows job is to finish putting the bumper back on then tackle replacing the door lock actuators
34by151
meirion1 (05-11-2017)
  #197
Old 05-12-2017, 08:34 PM
BlacXJRcat's Avatar
I finished installing the Mina mufflers. The installation is super easy. Now aligning them was a bia___.
In all honesty, I'm not sure I like the sound. It's quieter than the stock mufflers with the x pipe but with a deeper rumble. Not what expected. Maybe 200 cel cats may help.
  #198
Old 05-13-2017, 03:24 AM
exexpat's Avatar
Installed a 10" subwoofer. Did my best to make it look OEM+...
  #199
Old 05-13-2017, 06:12 AM
Wingrider's Avatar
Clean looking installation job.
  #200
Old 05-13-2017, 08:27 AM
BlacXJRcat's Avatar
Amazing! Excellent work. You should build and sell the enclosures.
Quick Reply: What did you do to your X350/X358 today?
