What did you do to your X350/X358 today?
Old 10-30-2019, 08:59 PM
PeteK812's Avatar
Joeleerj, I'm with you. When you buttress a plastic part with a stainless rib and epoxy bonder, the result is stronger than the OEM, so I'd prefer it. If any improvement were requested, a spray of matte black would finish it off.
  #862
Old 10-30-2019, 09:10 PM
joeleerj's Avatar
Thanks PeteK812,
It's many times stronger than OEM, and as far as the looks, (it's like many of our first girlfriends), it doesn't matter what she looks like as long as she performs satisfactorily.
The following 2 users liked this post by joeleerj:
jackra_1 (10-31-2019), roviw (10-31-2019)
  #863
Old 10-31-2019, 09:33 AM
Six Rotors's Avatar
Originally Posted by jackra_1
My original has a "P" button next to the shade button.
I totally missed that. In fact looking at all available on Ebay it seems to be very rare.
Anyway the color was wrong so I simply took off the wood trim from the grey console and xferred it to the tan one.
The grey one actually had an OEM microphone in it so was rare in more ways than one.
The "P" button was fitted to cars with both front and rear parking sensors and switches the parking sensors on and off.
  #864
Old 10-31-2019, 12:19 PM
jackra_1's Avatar
Received 1,756 Likes on 1,327 Posts
Yes I know thanks.
  #865
Old 10-31-2019, 06:04 PM
Received 1,425 Likes on 1,067 Posts
Yes it is.
At first I expected it to be "active" when I turned the ignition on and it was not so my first thought was uh oh. Once I started the car it did become active
with green direction letters.
Still have to "calibrate" it.
Just received mine today. I'll install on Sunday.
I see the computer board for the compass in the plastic moulding part.
This is awesome.
  #866
Old 10-31-2019, 06:33 PM
jackra_1's Avatar
You will like it even more when it is installed.
  #867
Old 11-04-2019, 10:30 AM
jackra_1's Avatar
This is awesome.
Did you install it yet abonano?
  #868
Old 11-04-2019, 03:20 PM
Today, hopefully if I get home before dark. Otherwise, tomorrow.
  #869
Old 11-13-2019, 04:58 AM
MarkBrzezinka's Avatar
Default contact
Hi Alec
We have met at Wray car show a few times. I have a blue daimler super 8. I wonder if I could talk to you about some upgrades I'd like to do?
  #870
Old 01-01-2020, 03:18 PM
I went to install the one I purchased originally last week and low and behold the metal strap that mounts the mirror assembly was missing. (Should've looked closer at the pics on the auction)
The seller was a douchebag and wouldn't accept the return. Karma's a bitch!
Anyways, sourced another and installed today. Love it.
No need to calibrate after switching the zone to 11.
Lines up perfectly with the GPS compass.
So now playing around with these assemblies I noticed once removed they are not as sturdy and shake going down the road. A fix is to take a wood shim and cut the end round and jam it between the assembly and mount.
Now it is rock solid! No shaking while underway...
The following 2 users liked this post by abonano:
Don B (01-16-2020), jackra_1 (01-02-2020)
  #871
Old 01-01-2020, 06:43 PM
Wingrider's Avatar
Like the compass in the mirror, better than in the view screen.
So i stuck a compass with a suction cup onto the windshield.
Reading it is much easier, than the one in the view screen.
  #872
Old 01-01-2020, 06:55 PM
Agreed.
Creative...
  #873
Old 01-01-2020, 08:22 PM
Wingrider's Avatar
Less expensive than another mirror, & it works well.
  #874
Old 01-02-2020, 08:40 AM
jackra_1's Avatar
I liked the Jag compass mirror so much I went ahead and added one to my 2013 Range Rover Sport.
Waaay more involved. I had to take out the guts from a compass mirror and place them inside my existing casing with the new compass mirror.
A bit of soldering was involved as well.
It is also a little loose so will use your wood wedge idea abonano.
  #875
Old 01-02-2020, 09:05 AM
domer94's Avatar
Originally Posted by OnebadassXJR
I finally got our CNC catch cans in, and I installed mine last night, tonight I'll finish when I get 1/2 hose. Looks awesome. $55 plus the ride if anyone is interested.
Ive noticed some oil burn in my 05 superv8. would this can control that? would you be able to supply one with some instructions for install? where are you in jersey? thanks
  #876
Old 01-10-2020, 07:34 PM
domer94's Avatar
just had a big one finished off today. front upper arms , rear upper and lowers , rear end links and tie rods. she drives and feels like new. when I had new tires donw I had a chance to really push and pull on things underneath .. and all the bushings and balljoints were torn up , and knocking about. at 126k miles , she really needed it. next is tracking down a rumble I feel through the floor at around 50mpn and 70mph... could be driveshaft bearing , or rear diff. the car keeps reminding me its worth it though....
  #877
Old 01-16-2020, 11:46 AM
jackra_1's Avatar
Default Replaced the rear crankshaft seal.
Old seal looks good so the phrase "if it ain't broke don't fix it" crossed my mind. However with the trans out might as well at 108,000 miles.
New seal in place. Not that easy to knock in without the proper tool!
Used this with a claw hammer as a sliding impact puller to get the old seal out.
Don B (01-16-2020)
  #878
Old 01-16-2020, 12:38 PM
XJ8JR's Avatar
Could possibly be a worn out transmission mount.
  #879
Old 02-02-2020, 06:50 PM
joeleerj's Avatar
Default Motor mounts
Replaced both mounts today. The right mount sprung a leak. Not a bad job, just had to make sure the engine was lifted high enough for clearance. I couldn't get the bolt off the right mount, because the stud separated fron the bottom of the mount and would just spin, so I had to cut it off using my reciprocating saw.
  #880
Old 02-15-2020, 10:25 PM
joeleerj's Avatar
Default Clock spring & Steering wheel
Removed and replaced faulty
Clock spring and refinished steering wheel
Quick Reply: What did you do to your X350/X358 today?
