What did you do to your X350/X358 today?
Old 08-16-2021, 07:22 AM
yellowbandit's Avatar
Originally Posted by James Teddy Gillis
Used JLR to update ECU and TCU.
Can you tell me more about this? I purchased my car last year, and I’m sure it hasn’t seen the inside of a dealer in years. What would i actually ask them to do, and what benefits could I expect?
  #1242
Old 08-17-2021, 03:46 PM
StagByTriumph's Avatar
@Yellow Bandit
The dealer will probably not replace the ECU or TCM unless either under a warranty, Factory Recall or if the ECU and/or TCM are fully diagnosed not functioning. Most dealers have a flat fee for diagnosing and upgrading to the last factory revision and I have found it is quite reasonable, less than $200 at some dealers.
Of course if you tell them you want to replace them regardless I am sure they will probably gladly accept your money - expect all that work to total in the range of $8k-$10K performed and warranted through a dealer, IF the dealer can locate the all new Jaguar Parts.
Note that a JLR dealer will only use New Genuine Jaguar parts, and can only substitute if there are no factory approved parts available. Most of that is due to liability issues.
Now if you have a friendly chat with the shop manager they might look for and reprogram used parts, but I doubt they will warrant them other than the labor.
  #1243
Old 08-17-2021, 04:33 PM
Ah. So it's "Check my ECU and TCU and be sure I'm running the latest software?"
I think I may need to invest in this! Is there a way to see what dates revisions came out so that I can check against the last time my car was in a dealership (according to CARFAX)?
  #1244
Old 08-17-2021, 05:29 PM
Originally Posted by abonano
Nice, but put NGK factory spark plugs back in...
No thanks. GREAT plugs but its happy. Tell you what, line up on a 40 roll and let's see how the plugs do
  #1245
Old 08-17-2021, 05:36 PM
I would imagine now days the dealer will do mostly what you asked as long as its not outside their liabilities. And a Manager may do anything but have you sign a waiver. I have a JLR/SDD updated to 2017. So I didn't need the dealer. Here in Miami they do not care. As long as you are paying, lol. Though I must say if you have a good rep with an advisor, cash will get the tech to do whatever, IJS. I believe investing in. JlR is a good idea. You can do so much more.
  #1246
Old 09-01-2021, 09:39 PM
J.A.G.'s Avatar
Default Some interior replacements.
During the last weekend, I was doing some changes in the interior, I was curious about combine others colors and I put a Black center console instead of the original because I wanted to have a better match with the stereo, I replaced the doors panels; I bought the material and made them, since that was my first time working with this kind of materials I think turned out well, I did the same with the center console, but just the bottom.
I have some others ideas for the trunk, but that will be later in a few weeks.
Center console
  #1247
Old 09-02-2021, 05:43 PM
novice19's Avatar
Default Modifications made in factory entertainment system
I had my premium entertainment system upgraded. First of all I had Jagdroid installed in my original Navigation system. As a result :
New touchscreen with HD resolution was installed
Android capability was added
BT Audio receiver dongle was installed to stream audio from the phone
A rearview/backup camera was added
Underseat Subwoofer was added
I added a converter to enable Apple Carplay
Attaching some photographs of the car that I washed today and the modified entertainment system
The following 2 users liked this post by novice19:
Etypephil (09-03-2021), J.A.G. (09-02-2021)
  #1248
Old 09-02-2021, 05:49 PM
J.A.G.'s Avatar
QUOTE=novice19;2435660]I had my premium entertainment system upgraded. First of all I had Jagdroid installed in my original Navigation system. As a result :
[/QUOTE]
Amazing
​​​​​​That's a clean Cat! Amazing.
novice19 (09-02-2021)
  #1249
Old 09-02-2021, 08:02 PM
novice19's Avatar
Thankyou!
J.A.G. (09-02-2021)
  #1250
Old 10-10-2021, 06:31 PM
joeleerj's Avatar
Default Vibration in rear end
I have been noticing a vibration in the rear end at highway speeds.So I finally checked it out and found the problem.The upper control arms and half shafts were shot. So I replaced them..
Changed both half shafts, threw the other one away before picture
The following 2 users liked this post by joeleerj:
J.A.G. (10-11-2021), Tigre (10-11-2021)
  #1251
Old 10-11-2021, 10:40 AM
J.A.G.'s Avatar
Nice, you did it by yourself? That's something that I need to check as well.
Thanks for th post.
  #1252
Old 10-11-2021, 04:24 PM
meirion1's Avatar
How many miles on the vehicle?
  #1253
Old 10-11-2021, 05:18 PM
joeleerj's Avatar
Exclamation
Thanks for the post.
Yeah, I did it myself. Not a difficult job. Just had to remember to disconnect to brake hose at the calipers.
J.A.G. (10-11-2021)
  #1254
Old 10-11-2021, 05:19 PM
joeleerj's Avatar
A little over 165,000
  #1255
Old 10-11-2021, 05:22 PM
J.A.G.'s Avatar
Default Thanks
Originally Posted by joeleerj
Yeah, I did it myself. Not a difficult job. Just had to remember to disconnect to brake host at the calipers.
Thanks for that detail about the brakes.
  #1256
Old 10-11-2021, 08:29 PM
joeleerj's Avatar
No problem. Didn't want you to be surprised.
J.A.G. (10-11-2021)
  #1257
Old 10-12-2021, 12:55 AM
Etypephil's Avatar
It's perfectly entitled to request a few replacement parts. Having owned some 89 cars including 25 Jags, 8 BMWs, and 4 Mercedes Benz, it never ceases to amaze me how well X350s and X358s stand up to time and miles. It can be difficult to tell a 50,000 mile car from a 250,000 mile one without checking the odometer.
The following 2 users liked this post by Etypephil:
meirion1 (03-19-2022), Petz (10-12-2021)
  #1258
Old 11-17-2021, 02:49 PM
Petz's Avatar
Default 2003 xj8 337000km
Currently trying to get the airfilter hose out of the plummerfitting on the original compressor (the one near the piston)
oil change is done the new compressor with dryer is waiting to get running
  #1259
Old 11-17-2021, 03:06 PM
Received 1,423 Likes on 1,066 Posts
Spray connection with a bit of WD40 - use the open end of a 12mm wrench - press down on the fitting, while pulling tube out.
The following 2 users liked this post by abonano:
Don B (11-18-2021), Petz (11-17-2021)
  #1260
Old 11-17-2021, 04:15 PM
Petz's Avatar
Laid a 12 then a 14 and a 16 on top of each other to give it some slight tapping with a hammer while using a prytool underneath the hose.
i already have a next idea for tomorrow.
i also opened and removed the bore /piston section and sprayed some dw 40 from underneath
Quick Reply: What did you do to your X350/X358 today?
