What Happens in Park?
OK, thought I understood that when you put a car in park, the transmission precludes the rear wheels from moving & the park brake was just an added safety feature.
However, I'm questioning my understanding after doing a brake job on my xjr.
Prior to starting the job, I stopped the engine with the park brake switched off. When I raised the rear of the car, the wheels did not turn at all. when I removed park brake calibers, the rear wheels turned easily. I drove the car prior to calibrating the park brake calipers & it seemed to rock back & forth in park, indicating that the drive wheels had some play in them.
Why did the wheels not turn with the park brake off and yet they moved when the calipers were removed(I would guess that the park brake was not actually off; however, the switch was held in the off position as I turned the ignition off.)? There seemed to be more wear than I expected on the disc. Could it be that my caliper was putting the park brake on when it was not needed? It never smoked or gave any other indication of being on when it shouldn't have been. Why did the wheels spin freely when suspended & yet allowed only a rocking motion of the car when it was lowered? Why did the transmission allow the rocking?
Hope this makes some sense & thanks.
Park lock the trans, so the rocking is play in the driveline
From the Owners manual
The parkbrake is automatically applied when the key is removed
from the ignition switch
The parkbrake is automatically released when the gear selector
is moved from the Park ‘P’ position
If the vehicle is stationary and the gear selector is in ‘D’ or ‘R’
and the parkbrake is applied, then the parkbrake will
automatically release when the accelerator pedal is depressed
To disengage the parkbrake, with the ignition switch in
position ‘II’ or with the engine running, apply the footbrake and
press the parkbrake switch down
34by151
34by151
The following 2 users liked this post by 34by151:
04Xjrsteve (02-15-2016),
philwarner (02-16-2016)
Both wheels will spin with an open differential if they are both jacked in the air. Unless you installed a quafe rearend (locker). The diff will only allow them to spin in opposite directions. That's the short way of describing how a differential works. If you need more info Google "open differential"
The following 3 users liked this post by Mark in Maine:
04Xjrsteve (02-17-2016)
34by151
34by151
Or does it have a braking function other than locking the transmission?
Yes you can apply/release the brake with the lever at any time including when moving
The caliper is mechanical but the operation is eclectic
The cable is pulled by a motor which in turn is controlled by the EPB module
The trans will lock the output shaft in Park. You need to put your foot on the brake to release the Park position though
34by151
34by151
They put the (rear) wheels onto a large powered roller and the test person operates the EPB (lifts paddle). The roller measures the braking force.
It is essentially the same as driving along and applying the EPB but the machine measures each side to check:
1. reasonably balanced side to side
2. sufficient force
(The main brakes are similarly checked.)
Things such as pad wear are also checked.
This is our annual inspection (MoT test) - the entire manual is free online if you want to see the detailed list of the whole car test.
In terms of common failures of the EPB I think a fair few are due to there typically being no maintenance done by owners. That and just age - things fail...
2. sufficient force
04Xjrsteve (02-18-2016)
I recall, when I was a child, my dad would get the car coasting down a hill in neutral and apply the e brake. We're atop a hill with a 30 - 45 degree grade; in memory of the old boy, think I will give it a try.
Thanks again, Jag V8, for bringing this to our attention. Next time i have the alignment checked, will have them put on the brake checking machine you mentioned.
FS[SouthEast]: Transmission & Engine Control Module
HectorM52
06-13-2016 07:30 PM
skullbiker
01-31-2016 02:54 PM
