What to look out for in an X350 - you need to know!
#63
Serious Electrical Ground Problem
Fantastic review of potential problems and fixes. Thanks to all. I might add that very often there are unusual electrical quirks (wiper/lights/engine/warnings) caused by poor grounds to the Al. body. In many areas of corrosion (salt, chemicals) the "posts" on the forward bulkhead (being the headlamps) seem to be the culprit even if they look OK. Good idea if there are unusual (particularly intermittent) electrical problems that defy logic and the OBDI, check these ground. Sometimes they look normal with no corrosion but when you attempt to remove the nut they fall off the bulkhead (remember that they are barely torqued down by Jaguar and do not over torque when replacing if they are OK). Thanks.
#65
#68
I have a 2004 VW Touareg with a V10 Diesel. 5800 pounds and air suspension. 113k on the clock. Never replaced any suspension parts. Air struts are fine. Suspension travel is 10 inches from lowest to highest. That part is pretty good. The rest of the car is a technical mechanical basket case. But you asked for one......
#69
Warm climate does help air shocks, but i doubt their still performing close to new.
My 04's front shocks had the slow leak issue in the cold.
Everything was still safe, & steered ok, but with new shocks, & tires.
Just go through things, to enjoy the car as much as possible.
Best used car deal out there, after some work, mine look and drive almost like new.
#70
Received 13,206 Likes
However, just because you don't have any apparent air leaks doesn't mean your suspension is operating as new. Shock absorbers are wear items, so there's a good chance yours are no longer damping as they did when new, especially on a three-ton vehicle. So just because you haven't replaced them (yet) doesn't mean you wouldn't benefit from doing so.
Cheers,
Don
#71
High Mileage Jaguars
great post CAMBO!
i'm researching purchasing new BBS wheels for my 2004 VP and i had no idea BBS made the OEM wheels! classy move JAGUAR!
this is my first post. i'd love to know how many members have 4.2L engines with 150K or 200K or 250K miles on them? i'd love to know how many miles this engine can go with regular maintenance and synthetic oil? any experience? any anecdotes?
Tim
Tim
My 1988 Jaguar XJ6 got up to 360,000 miles on the 3.6 liter I-6 engine. My 2003 Jaguar S-Type has the V8 4.2 liter engine and it is up to 210,000 miles. My first British racing green 2007 Jaguar XJ8L was purchased in 2015 with 90,000 miles and it is up to 152,000 miles now. The latest burgundy 2007 Jaguar XJ8L was purchased a week ago with 140,000 miles on it. I use Amsoil full synthetic oil on the cars which is rated for 12 months or 25,000 miles between oil changes.
#72
#75
It is nearly impossible to repair the hose because the part that fails is inaccessible at the point where is sits under the supercharger, upper hose barb/port and valley. The best solution from what I have seen is, connecting a 1/2 inch copper replacement tube to the fitting to the failed portion of the oem hose barb and the hose. Braided hose may last longer over oem. The part is not expensive from JAG, but the time it takes to replace it is the issue. Truthfully, once you do it, it is not as hard as the second time around. There is not much room to work around the front and back of motor to reroute with SC and TB in place.
#77
Just bought a Xj8 X350 and am quite pleased but...
I bought a x350 with a ignition coil problem and some rusty lugs
I replaced the breaks disk and all (they were original 17 years old)
I now need a catalytic converter and prep it for winter.
also a small coolant leak.
Great interior they literally do not make them like this anymore.
I have a deal with my mechanic I buy the parts and he puts them in
NO regrets its the coolest I have ever looked driving but really look at the car ahead of time I suggest even taking a code reader that you know will work to check out the car
Cino61 (07-06-2024)
#78
Hi Samuel,
Welcome to the Jaguar Forums! It's great to have you with us.
Please visit the New Member Area - Intro a MUST and post an introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers!
Don
Cheers!
Don
AD2014 (09-12-2020)
#79
Welcome aboard Samuel,;
These are great used car values, resale drops like a stone in water.
With their bad past reputation as well, a real asset when buying one.
My biggest expense, like many others is the suspensions replacement.
Both of mine needed the front & rears replaced.
Doing the work myself, cost around $3,000 a car.
The Arnott air shocks were about $900 a set
A major portion of the suspension cost.
A arms front & rear can be a bit trying, a lift is a real plus
A tune up, (spark plugs) trans filter, with fluid, cabin with air,& fuel filters.
I put a set of Chinese coils in as some of the stock ones needed lube sprayed on them to remove.
Tires, brakes, with an alignment should put you into pretty good shape.
Not trying to scare you off, but most previous owners just drove, them, & had the motor oil, & filter changed.
J.A.G. (08-29-2021)
#80
