What is this part of my tranny?
Hi guys,
In the enclosed pictures can you guys tell me what part this is, as you can see in one of the photos there's a leak . And I have to figure out how to fix it.
As an aside note I had the small 8 mm bolt that holds the shifter linkage to the transmission fall out and it rendered the car in operable . The car was in park but it thought it was in reverse.
The little bolt just fell out and was underneath the car and the other one that holds the shifter linkage to the tranny was loose I would recommend you getting under there and making sure those bolts are tight.
Thanks as always,
Griff
![What is this part of my tranny?-image.jpeg](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/136128d1474077234t-what-part-my-tranny-image.jpeg)
Thanks as always,
Griff
![Click image for larger version
ID: 136128](https://www.jaguarforums.com/forum/attachments/xj-xj6-xj8-xjr-x350-x358-28/136128d1474077234t-what-part-my-tranny-image.jpeg)
XJ-Executive
09-11-2016 06:25 PM
