What transmission fluid do i use? is there a cheaper solution?
Guest
Posts: n/a
Hello.
This is my first post.
I have a 2007 Jaguar XJ8.
My questions is, what kind of transmission fluid does it use?
dealer wants $60/liter for the oem fluid.
is there a cheaper solution to this?
Will it damage my transmission if i use regular atf fluid?
Someone help me with this please.
thanks
thanks
This is a much debated topic, unfortunately no cheap solution exists. You need to use the correct ZF fluid. I managed to find it as cheap as $38/bottle - still a steep price. Someone suggested checking wiht a BMW dealer, some 540 and 7 series have the same transmission.
There is a Castrol Import Multi Vehicle ATF, which may work, but is not 100% replacement. Even Castrol says you can experience reduced fuel economy as the new fluid has different viscosity. This to me sounds like a red flag.
Incorrect ATF fluid can have very unfortunate effects on yout transmission and would defenitely void your warranty.
Your 07 XJ should still be in warranty, why do you need to change the transmission fluid? The unit is "sealed for life" - which means it's probably good to at least 60k miles.
Good luck.
Good luck.
aholbro1
08-05-2021 06:02 AM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 12:56 PM
chatmanx
09-11-2015 08:17 PM
