What is up with condensation on the outside of the windshield in 100 degree heat?
Hello everyone:
My wife and I are riding around Houston in her work in progress 05 VDP. We turn on the ac and low in the windshield on both drivers and passenger side. The windshield begins to fog up on the outside of the car. Yes, you can use the windshield wipers to remove it. BUT why is it fogging up on the outside. I read all the responses. Turn down the temp and turn off the circulation button. This does work after awhile. But in 100 degree heat, this should not be happening. Could some directional flap not be working with ac on? Thanks for your help.
JDog
JDog
Defrost vent is open, blowing cold air up to the windshield. The humidity is condensing, just like it does on a cold drink.
As for why the defroster vent is open, I couldn't tell you if it's broken, not closing, an actuator failure... i would imagine it's a true pain in the butt to get to, though, like anything under the dash of any car.
The following 2 users liked this post by wfooshee:
Aarcuda (08-12-2022),
John in Tennessee (07-26-2022)
Hello everyone:
JDog
JDog
It sounds to me to be normal. I have heard from many people that this is happening to them. I just don't know how to fix it. I guess I will get a dark towel across the defrost vents unless anyone can chime in on how to fix it. I hate to have to tear into the a/c unit to find a vent that is blocked. I wish it was a some control module that was bad and I could replace it.
Condensation will occur anytime the temperature of the collecting surface (windshield) is below the dew point. Houston is a very humid environment. I'm in Florida which is also a very humid environment and the current temperature is 82 and the dew point is 77. In theory, condensation will collect on any surface that is colder than 77 degrees. A good example of this is when you get out of your air conditioned car in the summer and the lenses on your sunglasses fog up. The lens is colder than the dew point and condensation occurs. In the winter when the collecting surface is colder than the dew point and the dew point is below freezing, frost will eventually form. This is one reason why aircraft windshields are heated. The windshield on my 2005 Super V8 is heated to prevent this as well.
